Topic: Foobar2000 format strings (Read 473392 times) previous topic - next topic
Reply #1200
In order not to have %album% repeated I use something about as basic as
$if($strcmp(%tracknumber%,01),$if2(%album% - ,'n/a - '))
You mean dividers like this?
As for streams titles hmm I think you have to use <whatever>%title% instead of %_filename%, and make sure "Show dynamic info" is checked (in prefs|display) as well as "Enable dynamic track titles" (in prefs|http reader)
Reply #1201
QUOTE(Olive @ Jan 26 2005, 05:01 PM)
3) Who's the girl in your avatar? =)
You shouldn't have told everyone it wasn't you JEN..........you might not get your post responded to as quickly now!!
oh it wasnt you........I need to read more carefully b4 posting
Reply #1202
Darn!
I blame poorimpulsectrl
Oh well, looks like I will have to show you guys my real picture.
As its better
Reply #1203
  @ JEN
Reply #1204
[a href="index.php?act=findpost&pid=270193"][{POST_SNAPBACK}][/a]
I have drawn a diagram of what I'd like
The 2nd column on the left (containing 16B - How To Live 100 Years) shows %_directoryname% . I want a divider (the red line drawn) to be placed in between files from different directories.
I have drawn red x's through the redundant directory names on the left - I just want it so that the first time a file from a directory is displayed, the directory name is displayed on the left. For all other files from the same directory , I don't want the directory name displayed. I see this in many people's configurations.
Regarding the radio stuff, I have dynamic info checked , etc. What I need is the IF statement to add, so that if I am listening to an internet radio station, it will display %title% instead of %_filename%.
Reply #1205
Separators: Add this to the colour tab - although it's probably not the fastest method
//txt
|//txt
|//bg
|//bg
|//bg
|//left
|//top frame
$if($and($not($strcmp($add(1,%_playlist_number%),2)),
$strcmp($substr(%_filename%,1,2),01)),0000FF,000000)
|//right
|//bottom
No repeat: $if($strcmp($substr(%_filename%,1,2),01),%_directoryname%,)
Dynamic titles: $if($strcmp($substr(%_path_raw%,1,7),'http://'),[%artist% - ]%title%,%_filename%)
Reply #1206
Thank you so much Olive. I will give that a try now.
So just to clarify - I should past the separators part to all the columns I have, into their colour fields?
And the no repeat parte to the display tab of my directory column?
dynamic titles to the display tab of my filename column?
Sorry for the dumb questions and thanks again .
Reply #1207
Yes... You could use globals|colours instead of pasting to all columns -)
Note that I correlated your use of %_directoryname% and %_filename% to the screenshot you posted, and then assumed your naming pattern to be artist - album\tracknumber - title.ext. That will only work in that case, but if you got other patterns we can still add some $and() -)
Edit: BTW the comments were there to locate the top frame, you must delete them (replace |//txt with | etc.)
F. ex.
ffffff||000000||||$if($and($not($strcmp($add(1,%_playlist_number%),2)),
$strcmp($substr(%_filename%,1,2),01)),0000FF,000000)||
Reply #1208
F. ex.
[a href="index.php?act=findpost&pid=270343"][{POST_SNAPBACK}][/a]
Holy %*$%*(! Thank you so much Olive. I took your streaming radio string and managed to figure out how to get it to work with my existing string. Now the name of a stream will show if I'm listening to radio, otherwise my normal string seems to work fine!
Going to play with your strings on removing redundant directories and adding dividers between different directories. I tried putting them in earlier today and it seems there are some things I need to fix.
Thank you again!
Reply #1209
i know you all are going to hate me, but!  i've been checking out all these crazy designs you've all been making and wanted to know if there was a place you could point me to to learn all this string formatting. i know foobar comes with a semi-manual but is there a site i can go to that will explain all this.
Reply #1210
[a href="index.php?act=findpost&pid=272192"][{POST_SNAPBACK}][/a]
Sorry, I'm not aware of any resource like that. I learned string formatting by following this thread and hacking an early formatting string from Jan S that I liked, consulting the syntax help page that comes with Foobar (Prefs > Display > Title formatting > Help button). You can learn a lot by changing strings and seeing what happens.
Reply #1211
thats kinda what i figured.  okay im gonna do it the honorable way and RTFM!!!
Thanks for the reply
Reply #1212
another question.  how would i view a .fcs i've downloaded to use as a template to play with?  i cant seem to find it anywhere in prefs.
Reply #1213
[a href="index.php?act=findpost&pid=272424"][{POST_SNAPBACK}][/a]
in columns_ui settings, in the "other" tab, click the "import" button and import the fcs file.  if you've already done some configuring of your own and you don't want to lose it, be sure to "export" your config to an fcs file so you can recover it later.
Reply #1214
There's so many posts here. I could never try them all. Can someone recommend one excellent title formatting string?
Reply #1217
I'm very sorry. I had a little error in "my" code that showed 10 gray dots when a song was unrated. This should be fixed with this string:
$if(%rating%,$repeat(000000|000000●,%rating%)$repeat(C0C0C0|C0C0C0●,$sub(5,%rating%)),C0C0C0|C0C0C0●●●●●)
Regards,
Moon
[a href="index.php?act=findpost&pid=262081"][{POST_SNAPBACK}][/a]
Hi Moon,
I get the rating showing up in the Track Info correctly, but all that shows in teh rating column in 5 grey circles...  What am I missing?
Thx.
Reply #1218
This isn't very complex formatting, but I worked for quite a bit on both my systray strings, and my colour scheme
http://startrooper.free.fr/fb2k1.png
http://startrooper.free.fr/fb2k2.png
$padcut(:: ['['#%tracknumber%']'] [%album%],55)$char(13)$char(10)
$padcut(:: [$if($and(%va%,%performer%),%va% - %artist%,$if2(%va%,%artist%))],55)
[$char(13)$padcut(:: '('$if($or(%performer%,$not(%va%)),%performer%,%artist%)')',55)]$char(13)$char(10)
$padcut(:: [%title%],55)
which gives a popup :
:: [#01] Disque 1
:: Trésors du Cinéma - Richard Strauss
:: (Orchestre de Philadelphie)
:: Ainsi Parlait Zarathoustra
or, in less-tagged files,
:: [#09] The Cello Suites : Inspired by Bach (Disc 1)
:: Yo-Yo Ma
:: Suite No. 2, Courante
and it also truncates the titles, artists and disc names to prevent double-line entries.
Reply #1219
how to align %_length% to right of playlist (without using ui columns)??
Reply #1220
[a href="index.php?act=findpost&pid=322488"][{POST_SNAPBACK}][/a]
$tab()%_length%  or $char(9)%_length%
Reply #1221
ideas i'm playing with:
-check mark appears on left when track has been submitted to audioscrobbler
-playing track color fades from bright blue to white as track approaches end
-playcounts are brighter for more recently played tracks, and fade up to white from previous shade as track approaches 50%
-topdownjimmy from the gallery thread
Forgive my noobness, the little I do know about scripting can't even touch this. I'd owe you guys big if you could show me how to do these 3 things.
Reply #1222
Okay, as I've been waiting for a reply here, I've been making attempts at coding this myself. After about 10 collective hours (I told you I was a newbie) I've managed to come close to getting my 2nd question figured out. "-playing track color fades from bright blue to white as track approaches end"
Here's the code I made, It's uber-sloppy and I can't think of any better solutions.
//********** Countdown
$puts(10_color,158E21|2177A5)
$puts(9_color,168420|2891C8)
$puts(8_color,177B20|3EA3D9)
$puts(7_color,17711F|4EAADC)
$puts(6_color,18681F|61B4E0)
$puts(5_color,195E1E|71BBE3)
$puts(4_color,1A541D|7BC0E6)
$puts(3_color,1B4B1D|86C6E8)
$puts(2_color,1B411C|96CDEB)
$puts(1_color,1C381C|A8D6EE)
//10
$if(%_isplaying%,$ifgreater(11,%_time_remaining_seconds%,$get(10_color)$num(%_playlist_number%,$len(%_playlist_total%)).' ',))
$if(%_isplaying%,$ifgreater(11,%_time_remaining_seconds%,$get(10_color)[$get(artist) - ],))
$if(%_isplaying%,$ifgreater(11,%_time_remaining_seconds%,$get(10_color)[$get(album) - ],))
$if(%_isplaying%,$ifgreater(11,%_time_remaining_seconds%,$get(10_color)[$get(title)]                           ,))
$if(%_isplaying%,$ifgreater(11,%_time_remaining_seconds%,%_time_remaining_seconds%,))
//If time remaining is greater than 10 seconds, show normal string.
$if(%_isplaying%,$ifgreater(%_time_remaining_seconds%,10,438B7C$num(%_playlist_number%,$len(%_playlist_total%)).' '[$get(artist) - ][$get(album) - ][A0EBE1$get(title)]                           ,))
Is there a function that I could use as an "equal to"? For example $function(%_time_remaining_seconds%,9)
Any help would be greatly appreciated.
Reply #1223
[a href="index.php?act=findpost&pid=325002"][{POST_SNAPBACK}][/a]
$strcmp is a popular choice.  For example,
$strcmp($num(%_time_remaining_seconds%,2),09)
see titleformat_help.html in your foobar directory
Reply #1224
I would use a select for this
// this limits to 11 colors, the 10 count down ones, and the normal one
$select($min(%_time_remaining_seconds%,11),
$get(1_color) DISPLAY STUFF HERE,
$get(2_color) DISPLAY STUFF HERE,
$get(3_color) DISPLAY STUFF HERE,
$get(4_color) DISPLAY STUFF HERE,
$get(5_color) DISPLAY STUFF HERE,
$get(6_color) DISPLAY STUFF HERE,
$get(7_color) DISPLAY STUFF HERE,
$get(8_color) DISPLAY STUFF HERE,
$get(9_color) DISPLAY STUFF HERE,
$get(10_color) DISPLAY STUFF HERE,
DISPLAY NORMAL STUFF HERE)
although putting the same thing but changing the color 10 times is kind of redundant, I would maybe use another variable like curr_color, which would be set depending on the time left like above, and use that for all tracks.
