Topic: Buffered Ogg Files (Read 4601 times) previous topic - next topic
Buffered Ogg Files
I have looked at the options for ogg file types in Winamp and it has the option of buffering full files from disk.  What does this actually mean? I'm a bit new with ogg format, but I like it.
:Foobar 2000:
:MPC --standard:
:iRiver H320 Rockboxed:
Buffered Ogg Files
Thats means that Winamp will "copy" the whole Ogg file in RAM.
So it will going to read the file "from" RAM an not from the disk... this probably give more stable playback if the disk is busy...
JorSol
aoTuVb5 -q4
Buffered Ogg Files
Hmm I've been having problems with Winamp at the moment so I might try that, thanks for the info.
:Foobar 2000:
:MPC --standard:
Buffered Ogg Files
[a href="index.php?act=findpost&pid=363459"][{POST_SNAPBACK}][/a]
problems like??
It generally isn't necessary to buffer full files, it just wastes memory.. especially if you ever try to play a very large file
Vorbis-q0-lowpass99
lame3.93.1-q5-V9-k-nspsytune
Buffered Ogg Files
buffering is allocating space in memory for a stream, especially if it's in realtime.  If you are having problems with Winamp you might want to decrease the buffer size on the decoder, etc.
budding I.T professional
Buffered Ogg Files
Thanks for the help guys.
:Foobar 2000:
:MPC --standard:
