Ok, I don't know what the problem is, but using foo_contextsort and right clicking on the playlist appears to shut down foobar 7.7, then it creates and opens a failure.txt file with the following:
Illegal operation:
Code: C0000005h, flags: 00000000h, address: 00428FB7h
Access violation, operation: read, address: 00000000h
Call path:
WinMain=>app_mainloop
Code bytes (00428FB7h):
00428F77h: 40 C3 8B 44 24 04 83 F8 5C 74 2B 83 F8 2F 74 26
00428F87h: 83 F8 7C 74 21 83 F8 3A 74 1C 83 F8 2A 74 17 83
00428F97h: F8 3F 74 12 83 F8 22 74 0D 83 F8 3E 74 08 83 F8
00428FA7h: 3C 74 03 33 C0 C3 33 C0 40 C3 8B 4C 24 04 33 C0
00428FB7h: 38 01 74 0D 3B 44 24 08 73 07 40 80 3C 08 00 75
00428FC7h: F3 C3 8B 4C 24 04 33 C0 66 39 01 74 0E 3B 44 24
00428FD7h: 08 73 08 40 66 83 3C 41 00 75 F2 C3 56 8B 74 24
00428FE7h: 0C 57 8D 46 01 50 FF 15 58 E1 42 00 8B F8 59 85
Stack (0012FA10h):
0012F9F0h: 00000018 0012FC9C 8475CDD8 8475CAE8
0012FA00h: 00000000 8475CBA4 80526A60 804D5ED0
0012FA10h: 0042906C 00000000 FFFFFFFF 0238DA10
0012FA20h: 0208C4C8 0012FA94 0094133C 00000000
0012FA30h: FFFFFFFF 00949598 0012FA58 0094190A
0012FA40h: 00000007 0208C4E8 0012FA94 00000001
0012FA50h: 00949598 0012FB00 0012FAD8 004123BE
0012FA60h: 00000007 0208C4E8 0012FA94 02390601
0012FA70h: 10002D2F 0208C4C8 0206D738 0042E3CC
0012FA80h: 00000000 00000000 00000000 00000000
0012FA90h: 00000000 0042E3CC 00000000 00000000
0012FAA0h: 00000000 00000000 00000000 0238D8D0
0012FAB0h: 00000400 00000220 00000001 0041C4AA
0012FAC0h: 00949598 00000003 0208C4C8 023DA210
0012FAD0h: 00000012 00000003 0012FB44 00412C54
0012FAE0h: 00000140 0000000E 00000000 0208C4C8
0012FAF0h: 00D7B88F 0206D738 00D7232B 000B00C2
0012FB00h: 0012FB3C 10002D2F 0206D738 00000000
0012FB10h: 00000000 77D440C6 10002D2F 00D71FD9
0012FB20h: 00000000 0012FB18 77D43B1F 0012FBE8
Registers:
EAX: 00000000, EBX: 0012FA94, ECX: 00000000, EDX: 0042E3CC
ESI: 0208C4C8, EDI: 0012FA94, EBP: 0012FA38, ESP: 0012FA10
Crash location: "foobar2000", loaded at 00400000h - 00440000h
Loaded modules:
foobar2000 loaded at 00400000h - 00440000h
ntdll loaded at 77F50000h - 77FF7000h
kernel32 loaded at 77E60000h - 77F46000h
USER32 loaded at 77D40000h - 77DCC000h
GDI32 loaded at 77C70000h - 77CB0000h
ADVAPI32 loaded at 77DD0000h - 77E5D000h
RPCRT4 loaded at 78000000h - 78086000h
COMCTL32 loaded at 71950000h - 71A34000h
msvcrt loaded at 77C10000h - 77C63000h
SHLWAPI loaded at 63180000h - 631E5000h
utf8api loaded at 10000000h - 1000B000h
comdlg32 loaded at 763B0000h - 763F5000h
SHELL32 loaded at 773D0000h - 77BC2000h
foo_albumlist loaded at 008B0000h - 008B9000h
foo_ape loaded at 008C0000h - 008DF000h
foo_burninate loaded at 008E0000h - 008EB000h
VERSION loaded at 77C00000h - 77C07000h
foo_cdda loaded at 008F0000h - 008FE000h
foo_clienc loaded at 00910000h - 00924000h
foo_console loaded at 00930000h - 00938000h
foo_contextsort loaded at 00940000h - 0094B000h
foo_delete loaded at 00950000h - 00956000h
I found that foo_contextsort is the problem by removing plugins. Maybe there's some incompatibilities with 7.7? It worked great with 7.6.
edit: doh, didn't see the other thread
