Topic: 1.6.6 beta 2 search is slow (Read 1307 times) previous topic - next topic
1.6.6 is too slow to search compared to 1.6.5.
Please see the attached files.
(All files-404836- are in the monitoring of the media library.)
Re: 1.6.6 beta 2 search is slow
Problem acknowledged, thanks for reporting.
Should be improved in beta 3.
Strange. I can't feel the difference.
Note that you can see measured time it took to fetch the results in Console. Please post what it says in 1.6.5 vs 1.6.6.
It would help if you could export the offending playlist (right click the tab, "Save Playlist", FPL file) and send the FPL file to me for analysis, I should be able to recreate the exact scenario then.
I tested playlists of over 100000 items and saw speed differences but nothing nearly as bad as on your videos.
1.6.5 console log
Components loaded in: 0:00.539123
Configuration read in: 0:00.076015
foobar2000 v1.6.5 [standard]
Watching: D:\Music
User Interface initialized in: 0:00.084543
Loading
FFmpeg version: 4.3.1
Autoplaylists initialized in: 0:00.185396
"All Music" : 0:00.185376
Startup time : 0:02.284570
Search took 0:00.370583
Search took 0:00.357942
Search took 0:00.363416
1.6.6 beta 3 console log
Components loaded in: 0:00.013091
Configuration read in: 0:00.002009
foobar2000 v1.6.6 beta 3 [standard]
Watching: D:\Music
User Interface initialized in: 0:00.089854
Autoplaylists initialized in: 0:00.170419
"All Music" : 0:00.170409
Loading
Startup time : 0:01.578543
Search took 0:02.369025
Search took 0:02.294454
Search took 0:02.236732
I will send you the FPL file.
Problem recreated, thanks for all the details.
Beta 4 will correct this.
Update: beta 4 posted.
I have confirmed that the problem has been fixed. Thank you!
