Passive bi-amping with AVR
Reply #54 – 2015-06-03 10:23:41
He says, and I'm paraphrasing : bi-amping into loudspeaker cross-over filters, means that when one amplifier is working the other one is not. It is the same as connecting the amplifiers in parallel (theoretically), thus in essence having one amplifier only. There is however the point of headroom. When the peaks of a l.f. and h.f. signal happened to occur simultaneously, the voltages add, which will not happen with separate amplifiers. Thus a bi-amping system will have a higher headroom capability. Both amplifiers are working and outputting the same voltage, the same fullrange signal... As for current and power, well, the LF amp will maybe have to deliver a dB less because instead of the tweeter it will see the increasing impedance of the low-pass filter. It's only 1-2 dB or so because the spectrum of music behaves a bit pink noise so power falls off about 3 dB per octave. The HF amp needs to output a lot less power, but needs to be running so overall efficiency will be (quite a bit) lower. Clipping due to running out of voltage swing will be identical in both amps, again because both amplify the same signal. Only in terms of power you can gain the aforementioned dB. This is why it's called fool's bi-amping, because if you run into clipping you should simply buy a better amp that will give you a lot more headroom. In case of an AVR I see no problem, but also little advantages.
