HydrogenAudio
Hosted Forums => foobar2000 => 3rd Party Plugins - (fb2k) => Topic started by: jazzphunk on 2009-12-02 10:09:35
Title: Columns UI: toggle between different foobar layouts
Post by: jazzphunk on 2009-12-02 10:09:35
I have saved two different foobar layouts (a full-screen view and a reduced small view - so I can toggle between the views similar to Windows Media Player). Now I have assigned a button in the taskbar to switch between the saved layouts (the button allocated to the Main Menu Item: View/Layout/Name of Layout). The switch itself works fine, but it doesn't change the window size as well: I have to manually reduce/maximize the window size.
Is there any way to combine these functions in one button (in Columns UI) and to save some clicks?
Post by: 2E7AH on 2009-12-02 10:53:58
Although you can lock panels to custom size, you can't lock main foobar window size, so you can't do that
