HydrogenAudio
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: yq on 2003-02-05 17:45:00
Title: What's Monkee Limiter...
Post by: yq on 2003-02-05 17:45:00
...and in what is it different than 'Soft clipping limiter' (Soft clipping limiter is 6dB hard limiter, right)
[span style='font-size:8pt;line-height:100%']edit: ghrrr..... doesn't seem I can edit the title. Should be 'Monkee limiter'.[/span]
[span style='font-size:8pt;line-height:100%']edit2: I see somebody edited the topic. Thanks Somebody .[/span]
Post by: voltron on 2003-02-05 17:50:25
monkee limiter reads ahead while the soft limiter does not, afaik. monkee limiter is hence better but adds more dsp latency.
Post by: musicmusic on 2003-02-05 18:16:28
as far as i know, soft limiter is active all the time, but monkee's limiter is more intelligent and onlys does its stuff when it actually needs to.
Post by: David Nordin on 2003-02-05 21:03:41
yes omg t3h horrifying 5ms delay!!! OMG DE4TH!  (w00t)
I could make that less after some modification but there's some other stuff to do first.
anyway, it's a more efficient limiter, it doesn't clip like the soft clipping limiter and it's transparent 'til it clips.
no, there is no always-present limiter in foobar - you choose which you want.
have a look here (http://www.hydrogenaudio.org/forums/index.php?s=&act=ST&f=24&t=5797&view=getlastpost).
a lil hint, it's always advice to browse old threads before making new threads.
btw. "monee limiter" is that nasty thing called tax
Post by: Ghim on 2003-02-05 21:30:59
It takes some more CPU time compared to soft clipping limiter... (still 0% for me but it's a bigger 0)
And those 5ms are so HUUUGE compared to my 300 ms KS latency... (w00t)
(lets imagine 5ms compared to 1000 ms for those with DS output :'( )
Seriously, this is great work and that's why I'm always using it (that's the only dsp I have activated on my PC ;-)
I don't have clipping musics... but this could happen and this'll proctect me from these without being always in "active" mode... B)
Just a question : Why did you name it Monkee limiter ???
Post by: yq on 2003-02-06 09:38:17
oops... I know, just didn't find it. sorry
And it is hard coded and always turned on
Post by: ak on 2003-02-06 12:41:45
Unless you use some dirty hacks to bypass it.
Post by: darkpark on 2003-02-06 13:27:00
or you're Willy Nelson
