Hello. Windows 10 x64, foobar2000 last. Sound card - creative audigy value se. With windows xp it was instantly/immediately.
P.s. ...After half a second or more.
Addition. When you press the hotkey for a long time, at the very beginning, the volume does not change instantly.
Do you change the volume as usual?
Do you have smooth seeking enabled in the preferences?
Preferences > Playback > Output | Fading
Disabled. It is necessary that the volume at the beginning changes a little faster.
what output method are you using, can you try exclusive mode to see if there is any difference
Checked. Wasapi output support 3.4. Event and push. Kernel streaming support 1.2.2. I don't see the word exclusive in foobar.
New feature in 1.6.7 beta, so if you want to stay on a stable release, that is not applicable to you (yet).
I have v 1.6.6 stable. After pressing the hot key, without releasing it, the volume changes by decibel, but then there is a short pause in changing the volume by ~ 3-4 deciseconds. How to disable/turn_off this pause?
You stop using outputs which require software volume control.
Change by decibel*. Do not understand this question? ...by ~ 3-3,6 deciseconds...
I understand. There's latency. Software volume control always has latency. Unless the OS is doing it. Then it becomes less noticeable.
This is always noticeable. And can't get used to it. That is, foobar will always with this pause because it's a program? Do you think the operating system is to blame?
All I suffer with the translator...
