I use this version https://foobar.hyv.fi/?view=foo_dsp_nogaps_wip because of the threshold option
Bug: it skips silence in the beginning of song too, cutting parts of some fade in intros like Metallica - Damage, Inc.
Changes (https://foobar.hyv.fi/?view=foo_dsp_nogaps)
0.4.6 (2023-03-16): Recompile with latest SDK and foobar2000 v1.5 compatibility.
0.4.5 (2022-09-05): Added foobar2000 v2.0 dark mode and 64-bit support.
0.4.4 (2020-02-22): Fixed a crash with sample rate change.
@Case, what do you think about it?
It seems I missed this topic when it was originally posted. To answer the question in the title - not possible with this component.
That Metallica's track has a very quiet intro. The beginning gets removed with the component's default settings as it falls below the default -50 dBFS loudness. Adjusting the threshold to only remove quieter unwanted signal is a solution for this track.
Anyway, this component was created in 2003. If I'm not mistaken I made it to get more pleasant listening experience with audio files of that era where gapless encoding wasn't really a thing. I revisited the component in 2017 and tried to make it automatically remove only unwanted gaps, but I didn't get it working perfectly. And I recall people wanted the manual control sliders back.
