HydrogenAudio
Hosted Forums => foobar2000 => General - (fb2k) => Topic started by: phunkydizco on 2021-04-26 18:45:13
Title: Alignment with custom grouping possible? [Default Playlist View]
Post by: phunkydizco on 2021-04-26 18:45:13
Hello everyone
Is possible to show the first part of a custom grouping scheme on the left side and a second part on the right. I want 'artist' and 'album' align to the left and in the same line 'codec' 'samplerate' and 'bitspersample' to the right.
Kind regards
A long term foobar2000 user
Title: Re: Alignment with custom grouping possible? [Default Playlist View]
Post by: anamorphic on 2021-04-27 15:04:12
Hi there,
Unfortunately so far right-aligned groupings are not possible with default playlist viewers.
The only playlist that I've seen with this feature are the script based playlists - 'JSplaylist main script.js' and 'JS Smooth Playlist.js' - included with JScript Panel (https://github.com/marc2k3/foo_jscript_panel/releases) / Spider Monkey Panel (https://theqwertiest.github.io/foo_spider_monkey_panel/). (Of course these playlist viewers look completely different to the default ones). I have not really messed with it but I think you can set left / right headers in 'JSplaylist main script.js' by right-click > Panel Settings > Groups. (?)
Cheers
Post by: phunkydizco on 2021-04-28 12:52:21
Thank you for your reply. I will stay with the default playlist view anyway.
