I want to encode some multichannel 5.1 FLAC files to m4a with QAAC.
I don't know the commands.
Right now I'm using this:
--ignorelength -s --no-optimize -V 127 -o %d -
I'm pretty sure this commands are for STEREO encoding.
What should I add to this command ?
The VBR setting you appear to be using would be quality based, which scales depending on the channel count.
Have you given it a try as-is and seen what the output looks like? https://github.com/nu774/qaac/wiki/Multichannel--handling (https://github.com/nu774/qaac/wiki/Multichannel--handling) . Also from qaac command line options:
--chanmap Rearrange input channels to the specified order.
Example:
--chanmap 2,1 -> swap L and R.
--chanmap 2,3,1 -> C+L+R -> L+R+C.
--chanmask Force input channel mask(bitmap).
Either decimal or hex number with 0x prefix
can be used.
When 0 is given, qaac works as if no channel mask is
present in the source and picks default layout.
And as kode54 indicated: "True Variable Bitrate gives you a specific quality. The bitrate is free to vary as much as necessary, and generally the more channels, the higher the bitrate, as you're specifying a quality regardless of the channel count. All the other encoding modes let you control the bitrate in some way, but the selected bitrate is not directly related to quality." (https://forum.videohelp.com/threads/378450-Best-settings-for-QAAC#post2444452 (https://forum.videohelp.com/threads/378450-Best-settings-for-QAAC#post2444452))
Chanmask should be handled automatically under foobar2000 anyway, as foobar emits WAVEFORMATEXTENSIBLE with a channel mask field.
