Topic: Query search retrieving bad results. (Read 1305 times) previous topic - next topic
I have a sort of problem here. I do a query search with '"album_rating" GREATER THAN 4' and I got approximately 300 songs on top of the image. Nevertheless, when I create a playlist the results include less than 4 rating albums, as for example 2'5 creating a playlist with more than 4000 songs. Maybe I am doing something wrong. Regards.
Yes, the avatar it is the cover of «The City» by Vangelis.
Re: Query search retrieving bad results.
You mean, 300 albums?
So what happens if you use the correct syntax %album_rating% GREATER 4?
I thought it were songs but they are albums and then on the playlist they are songs, that is why there are a lot more items.
I thought it was GREATER THAN, with GREATER 3.5 I got albums with 4, 4.5 or 5.
Thanks, both.
THAN is indeed incorrect. It's not a keyword and gets treated as text. Chances are your query returned every file in your library.
