Topic: WSH Panel Mod (Read 815119 times) previous topic - next topic
WSH Panel Mod
Reply #1700
@anyone who used this with windows 8 .... was the high cpu usage with JScript9 engine/on_mouse_move fixed by an update to windows 8 or was it only fixed when 8.1 came out?
WSH Panel Mod
Reply #1701
i can't tell, i had this issue with windows 8 but no more under 8.1 or 10, but as it fixed by a windows 8.0 fix or by 8.1, i can't tell...
Re: WSH Panel Mod
Reply #1702
Nevertheless i've made those two toolbars to replace foobar's standard ones :
Seekbar:
function RGB(r,g,b){ return (0xff000000|(r<<16)|(g<<8)|(b)); }
var g_font = gdi.Font("Tahoma", 12, 0);
var g_drag = 0;
var ww = 270;
var hofset = 10;
var wh = 12;
function on_paint(gr){
var vofset = (window.Height-wh)/2;
var length = fb.PlaybackLength;
var grad = 0;
if (length > 0) {
grad = fb.PlaybackTime/fb.PlaybackLength;}
var i = 0;
while (i < ww+1) {
var col = (grad<=0)  ? RGB(168,168,168) : (i<=grad*ww) ? RGB(0,32+48*(1-i/ww),96+64*(1-i/ww)) :  RGB(128+48*(1-i/ww),128+48*(1-i/ww),128+48*(1-i/ww));
gr.FillSolidRect(hofset+1+i,vofset,4,wh, col);
i = i +5;
gr.DrawRect(hofset,vofset, i, wh, 1.0, RGB(192,192,192));
function on_mouse_lbtn_down(x,y){
g_drag = 1;
on_mouse_move(x,y);
g_drag = 0;
function on_mouse_move(x,y){
if(g_drag){
var v = (x-hofset)/ww;
v = (v<0) ? 0 : (v<1) ? v : 1;
fb.PlaybackTime = fb.PlaybackLength * v;
function on_mouse_wheel(delta){
if(delta>0)
fb.PlaybackTime = fb.PlaybackTime + delta;
else
function on_playback_new_track(info){
window.Repaint();
function on_playback_stop(){
window.Repaint();
function on_playback_seek(time){
window.Repaint();
function on_playback_time(time){
window.Repaint();
Thanks NEMO7538 for the code.
I adapted it to my foobar2000 so the seekbar autoexpand to the window width.
var g_drag = 0;
var ww = 820;
var hofset = 20;
var wh = 24;
    var ww = window.Width-(2*hofset);
var grad = 0;
if (length > 0) {
var i = 0;
while (i < ww+1) {
var col = (grad<=0)  ? RGB(168,168,168) : (i<=grad*ww) ? RGB(100,32+48*(1-i/ww),96+64*(1-i/ww)) :  RGB(128+48*(1-i/ww),128+48*(1-i/ww),128+48*(1-i/ww));
i = i +5;
g_drag = 1;
on_mouse_move(x,y);
g_drag = 0;
if(g_drag){
if(delta>0)
else
window.Repaint();
window.Repaint();
window.Repaint();
window.Repaint();
Re: WSH Panel Mod
Reply #1703
Enjoy my glowing bluishness:
I don't remember if I have already post this or not, but here it is the seek bar I use, which is one of the best I've seen. I didn't make it though, I found it somewhere in the 'interwebs':
// Info Bar 0.1.2
// Copyright ©2010 Lediur
// Completely rewritten from the stock WSH Panel progress bar script.
// Licensed under BSD License
// License bits
// This script is considered an addon for WSH Panel Mod.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS
// AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED
// WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
// WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
// PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
// INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
// (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
// GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
// INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
// WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
// OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
// OF SUCH DAMAGE.
// Basic functions
// Evaluates color input
// INPUT: 3 values, RED GREEN BLUE;
//        4 values, RED GREEN BLUE ALPHA;
// RETURNS: Byte value representing the selected color
function RGBA(r,g,b,a){ return ((a<<24)|(r<<16)|(g<<8)|(b)); }
// Evaluates time from seconds
// INPUT: 1 value, SECONDS
// RETURNS: A formatted string representing the desired time.
function TimeFmt(t){
var zpad = function(n){
var str = n.toString();
return (str.length<2) ? "0"+str : str;
var h = Math.floor(t/3600); t-=h*3600;
var m = Math.floor(t/60); t-=m*60;
var s = Math.floor(t);
if(h>0) return h.toString()+":"+zpad(m)+":"+zpad(s);
return m.toString()+":"+zpad(s);
// String variables
//var title;
//var artist;
//var status;
//var time;
//var s_playbackOrder = "<NOT ACCESSIBLE>";
var title = "foobar 2000 ";
var artist = "v1.3.8";
//var artist = "%_foobar2000_version%";
var status;
var time;
var s_playbackOrder = "";
// Animation information
var playback_alpha = 128;
var playback_XPos = 0;
var playback_animating = false;
var animation_timer = false;
// Fonts
var title_fontsize = 36;
var artist_fontsize = 20;
var g_titlefont = gdi.Font("Arial", title_fontsize, 1);
var g_artistfont = gdi.Font("Arial", artist_fontsize, 1);
var g_statusfont = gdi.Font("Arial", 24, 1);
var g_timefont = gdi.Font("Segoe UI", 28, 2);
//var g_trackfont = gdi.Font("Arial", 18, 1);
var title_sizelimit = 36;
var artist_sizelimit = 20;
var title_width = 0;
var artist_width = 0;
// Dimension information
var info_width;
var margin = 20;
// Title Formats
var g_title = fb.TitleFormat("%title%");
var g_artist = fb.TitleFormat("[%artist%] / [%album%]");
var g_time = fb.TitleFormat("%playback_time%/%length%");
var g_status = fb.TitleFormat("♥%rating% ♪%play_count% %codec% %samplerate%Hz $caps(%channels%) %bitrate%kbps ");
//var g_track = fb.TitleFormat("%track%");
// Boolean variables for seek-checking
var g_drag = 0;
var g_drag_seek = 0;
// Gradient settings
var c_progtop = RGB(0,150,255);
var c_progbot = RGB(0,50,200);
var c_proglead = RGBA(0,30,255,255);
// Timer for updating progress bar and other items
var f_timer;
var timer_interval = 50;
var timer_interval_animation = 5;
var ww = window.Width;
var wh = window.Height;
var pos = 0;
    gr.SetTextRenderingHint(4);
    gr.SetSmoothingMode(2);
// Evaluation of information
if(length > 0){
if(g_drag){
pos = window.Width * g_drag_seek;
title = "Seeking: ";
            time =  TimeFmt(g_drag_seek * length) + " / " + TimeFmt(length);
else{
pos = window.Width * (fb.PlaybackTime / length);
title = g_title.Eval();
//            track = g_track.Eval();
            artist = g_artist.Eval();
            time = g_time.Eval();
            status = g_status.Eval();
// Title Size Update
    title_width = Math.round((gr.MeasureString(title,g_titlefont,0,0,ww,wh,0x00000400)).Width);
    if(title_fontsize > title_sizelimit)
title_fontsize = title_sizelimit;
    if(title_width > Math.round(ww - info_width - wh/2 - margin) || title_fontsize > title_sizelimit)
        title_fontsize -= ( title_width-Math.round(ww - info_width - wh/2 - margin) )/100;
    else if (title_width < Math.round(ww - info_width - wh/2 - margin) && title_fontsize < title_sizelimit)
        title_fontsize += ( Math.round(ww - info_width - wh/2 - margin) - title_width)/100;
// Artist Size Update
    artist_width = Math.round((gr.MeasureString(artist,g_artistfont,0,0,ww,wh,0x00000400)).Width);
    if(artist_fontsize > artist_sizelimit)
artist_fontsize = artist_sizelimit;
    if(artist_width > Math.round(ww - info_width - wh/2 - margin) || artist_fontsize > artist_sizelimit)
        artist_fontsize -= ( artist_width - Math.round(ww - info_width - wh/2 - margin) )/100;
    else if (artist_width < Math.round(ww - info_width - wh/2 - margin) && artist_fontsize < artist_sizelimit)
        artist_fontsize += ( Math.round(ww - info_width - wh/2 - margin) - artist_width)/100;
g_artistfont = gdi.Font("Arial", artist_fontsize, 2);
// FillGradRect ( Starting X, Starting Y, Width, Height, Gradient Rotation, Starting Color, Ending Color )
    // Background Bar
gr.FillGradRect(pos, 0, ww-pos, wh, 90, RGB(0,0,0), RGB(11,22,32));
    // Progress Bar
gr.FillGradRect(  0, 0,    pos, wh, 90, c_progtop, c_progbot);
    // Progress Bar Leader
    gr.FillGradRect(pos-3, 0, 50, wh, 180, RGBA(0,0,0,0), c_proglead);
    // Right Gradient
    gr.FillGradRect(ww-100, 0, 250, wh, 0, RGBA(0,0,0,0), RGBA(17,66,170,255));
// DrawString ( Output String, Output Font, Color, Starting X, Starting Y, Width, Height, Hex Values )
// /!\ NOTICE
// These values were determined through trial and error.
// They work fine on my computer and resolution, but
// you might want to tweak them to fit your taste.
// Unfortunately, I don't have documentation for the hex values.
// Here's what I figured out so far, though.
// 1: Alignment (0: left, 1: center, 2: right)
//    gr.DrawString(g_track.Eval(), gdi.Font("Arial", 18, 1), RGB(190,200,250), wh/14, -wh/10, ww-250, wh, 0x01000000);
//    gr.DrawString(title, g_titlefont, RGB(255,255,255), wh/2.5, -wh/5.7, ww-250, wh, 0x01000000);
    gr.DrawString(title, g_titlefont, RGB(255,255,255), wh/4, -wh/4, ww-250, wh, 0x01000000);
    gr.DrawString(artist, g_artistfont, RGB(255,255,255), wh/2.5, wh/4.5, ww-250, wh, 0x01000000);
    gr.DrawString(time, g_timefont, RGB(255,255,255), 0-wh/6, -wh/6.5, ww, wh, 0x21000000);
    gr.DrawString(status, g_statusfont, RGB(254,168,0), 0-wh/6, wh/4.5, ww, wh, 0x21000000);
    // Background Title
    info_width = (gr.MeasureString(status,g_statusfont,0,0,ww,wh,0x00000400)).Width;
    AnimateBackgroundTitle();
    gr.DrawString(s_playbackOrder, g_statusfont, RGBA(255,255,255,playback_alpha), ww-wh/6-info_width+playback_XPos, 0-wh/6.5, ww, wh, 0x01000000);
function AnimateBackgroundTitle(){
    if(playback_animating)
        if(!animation_timer){
            //fb.trace("-- Animation timer on - setting timer interval to " + timer_interval_animation);
            //fb.trace("-- Animation starting: >");
            f_timer = window.CreateTimerInterval(timer_interval_animation);
            animation_timer = true;
        if(playback_XPos <= 0)
            playback_XPos = 0;
        if(playback_alpha > 128)
        playback_XPos -= 1;
        playback_alpha += 1;
    if(playback_animating && (playback_XPos <= -1 || playback_alpha >= 129))
        //fb.trace("-- Animation finished.");
        playback_XPos = 0;
    if(!playback_animating && animation_timer){
        //fb.trace("-- Animation timer off - setting timer interval to " + timer_interval);
        f_timer = window.CreateTimerInterval(timer_interval);
// Resizes the text in the info panel
// INPUT: WSH Panel HEIGHT, WSH Panel WIDTH,
// /!\ NOTICE
function updateSize(){
    var font_size = title_sizelimit;
    // ====== TITLE SIZE COMPENSATION ======
    font_size = (window.Width - 50) / 25 + (window.Height-200)/10;
    factor = (window.Width - 400) / 100;
// Upper-bound font size limiter
if(font_size > 36)
font_size = 36;
// If we don't check for this we get the JavaScript
// equivalent of a NullPointerException.
if (title != null){
        font_size -= title.length / 100;
// Upper-bound width limiter
if(window.Width > 800) {
factor = 0;
// Lower-bound width limiter
        if(window.Width < 300)
font_size += window.Width / 70;
// Try to check for excessively long titles
if(title.length > 50)
font_size -= title.length / 7;
if(title.length > 70)
font_size -= title.length / 50;
     // ====== ARTIST SIZE COMPENSATION ======
     font_size = (window.Width - 50) / 40 + (window.Height-200)/20;
if(font_size > 24)
font_size = 24;
if (artist != null){
font_size -= artist.length / 120;
font_size += window.Width / 90;
if(artist.length > 80)
font_size -= artist.length / 22;
if(artist.length > 120)
font_size -= 6;
g_artistfont = gdi.Font("Arial", font_size, 2);
     // ====== TIME SIZE COMPENSATION ======
     font_size = (window.Height - 5) / 2;
     g_timefont = gdi.Font("Arial", font_size, 2);
     // ====== STATUS SIZE COMPENSATION ======
     font_size = (window.Height - 5) / 4;
     g_statusfont = gdi.Font("Arial", font_size, 1);
// Some of this stuff may be redundant,
// but it works fine on everything I've listened
// to so far.
function on_size(){
updateSize();
function on_focus(focused){
//fb.trace("focus " + focused);
function on_key_down(key){
//fb.trace("key " + key);
g_drag = 1;
    g_drag_seek = x / window.Width;
    window.Repaint();
if(g_drag){
g_drag = 0;
g_drag_seek = (g_drag_seek<0) ? 0 : (g_drag_seek<1) ? g_drag_seek : 1;
fb.PlaybackTime = fb.PlaybackLength * g_drag_seek;
// Allow for seeking
if(g_drag){
window.Repaint();
fb.PlaybackOrder += delta * 2;
    if(fb.PlaybackOrder > 4)
        fb.PlaybackOrder = 0;
            if(fb.PlaybackOrder == 4)
                //fb.trace("Playback Order: Shuffle");
                s_playbackOrder = "Shuffle";
            else if (fb.PlaybackOrder == 2)
                //fb.trace("Playback Order: Repeat");
                s_playbackOrder = "Repeat";
            else
                //fb.trace("Playback Order: Sequential");
                s_playbackOrder = "Sequential";
    playback_XPos = 128;
    playback_alpha = 0;
    playback_animating = true;
// Create a timer for updating the bar.
function on_playback_starting(cmd, paused){
// Update information, repaint on new track.
    else
updateSize();
    window.Repaint();
// Playback Stop
// CPU usage saver
    if(f_timer){window.KillTimer(f_timer);}
updateSize();
window.Repaint();
// Repaint every time we seek
window.Repaint();
// Changes the color of the bar based on the pause state.
function on_playback_pause(state){
    if(state){
    } else {
    //c_progtop = state ?  RGB(100,100,140) : RGB(0,150,255);
    //c_progbot = state ?  RGB(50,50,100) : RGB(0,50,200);
    c_progtop = state ?  RGB(0,0,30) : RGB(0,150,255);
    c_progbot = state ?  RGB(0,0,0) : RGB(0,50,200);
    // c_proglead = state ?  RGB(5,29,84) : RGBA(20,30,255,255);
    c_proglead = state ?  RGB(10,58,168) : RGBA(20,30,255,255);
    window.Repaint();
// Repaint every tick
function on_timer(){
    window.Repaint();
//EOF
Re: WSH Panel Mod
Reply #1704
that script contains old functions no longer supported in this component. i do mention it in the readme but it's completely my fault for not providing a link to it from the releases page. sorry for the inconvenience.
https://github.com/19379/foo_uie_wsh_panel_...aster/README.md
you should use the official component because i'm not updating other people's scripts.
Ok, I'm understand, but, I don't know who write this script, and can't write new one. I'm a medic. Mark, may be ... you look it, pleeeeees....
Eiko was too old, so do not try to update it's WSH Panel Mod component to 1.5.6+.
A rose will bloom, it then will fade.
