Topic: MUSHRA (Read 5287 times) previous topic - next topic
MUSHRA
Hi All,
I want to know whether there is any available free software for performing subjective tests and which follows the methodology given by ITU-R BS.1534 (i.e. MUSHRA).
I also want to know the approximate cost for CRC's SEAQ software.
-rvanam
MUSHRA
ABC/hr is only slightly more complicated than MUSHRA:
http://ff123.net/abchr/abchr.html
with the added benefit of forcing the listener to distinguish from a hidden reference each time a rating is performed.  The optional hidden anchors are added separately as if they were additional samples to be rated.
ABC/hr also has an ABX module for determining difference only, for extremely subtle artifacting.
ff123
MUSHRA
ff123
[a href="index.php?act=findpost&pid=258286"][{POST_SNAPBACK}][/a]
I want to perform subjective tests using the procedure mentioned in MUSHRA. I also want to avoid the complexity of distinguishing from a hidden reference each time a rating is performed as in ABC/HR. Is it possible to modify ABC/HR to avoid this complexity or are there other freely available tools for MUSHRA?
regards,
rvanam
MUSHRA
ff123
regards,
rvanam
[a href="index.php?act=findpost&pid=263691"][{POST_SNAPBACK}][/a]
There is Ivan Dimkovic's "waverate" program, but it is buggy:
[a href="http://faac.sourceforge.net/oldsite/tests.php]http://faac.sourceforge.net/oldsite/tests.php[/url]
Other than that, I don't think there are any freely available MUSHRA-type programs.
Of course, you are free to modify the source code of abc/hr to suit your needs
ff123
MUSHRA
If you're using MUSHRA appropriately (i.e. on obviously non-transparent signals) the presence of the hidden reference shouldn't add much time to the experiment - and it will weed out deaf listeners.
I can imagine it will look neater and simpler without the hidden reference, but when running an actual test it's simplicity itself.
