Topic: foo_vis_shpeck (Read 741168 times) previous topic - next topic
Re: foo_vis_shpeck - My way of using relative path for shpeck for portable fb2k
Reply #825
My way of using relative path for shpeck for portable foobar2000 installation:
1. open foo_vis_shpeck.dll in hex editor and change "C:\Program Files\Winamp" to ".\fx" (keep original file size, add some "00" byte padding if needed)
2. remove foo_vis_shpeck.dll.cfg from the configuration directory
3. create "fx" directory in foobar's root directory, create there empty winamp.exe file and Plugins subdirectory
4. put all your winamp's vis plugins into .\fx\Plugins\ directory
5. create foobar2000.bat in foobar's root dir to run foobar2000 from:
set foobar_root=%~dp0
set PATH=%PATH%;%foobar_root%
start foobar2000.exe
6. run foobar2000.bat
7. open shpeck configuration pane, plugins list should be populated
8. run any desired visualization, it should be working
PS: foobar2000 uses "traditional" way of dll loading, i.e. any dll should have absolute path OR be in the %PATH% variable. That batch file temporarily adds foobar's root directory to the environment, in which foobar then runs. After that, foo_vis_shpeck.dll tries to load dlls from .\fx\Plugins, but it will succeed only if it find the first part of foobar's root directory (which is in the %PATH% now). That's it.
Added modified foo_vis_shpeck.dll so you don't have to edit it.
Re: foo_vis_shpeck
Reply #827
No. Yirkha has moved onto other things, mostly employed by MS.
Re: foo_vis_shpeck
Reply #829
Cheers. Yeah, unfortunately ProjectM is a very poor substitute for Milkdrop in a number of ways. It's missing many of the features, doesn't load all the Milkdrop presets properly, has no settings or title display options etc.
Re: foo_vis_shpeck
Reply #830
I could never get it to work either, so I'm still using Milkdrop. I have no plans to move to 64bit for the foreseeable future anyway.
Re: foo_vis_shpeck
Reply #831
Oh man what a bummer. I do want to upgrade to v2.0 64-bit though.
ProjectM is a no go. Doesn't load any of Martin/Nitorami's presets properly (some of the best presets out there).
I wonder if the unofficial Milkdrop3 is any better.
github /milkdrop2077/MilkDrop3/
Re: foo_vis_shpeck
Reply #832
Hi, any chance to add dark mode to Shpeck?
Re: foo_vis_shpeck
Reply #833
Can't launch the milkdrop config panel in f2k v 2.0 32bits, any idea what can be and how to fix it?. No problem in f2k v1.6.12
I had two instances of f2k open (v1.6.12 and v2.0). Now there is no problem  :D
Re: foo_vis_shpeck
Reply #834
Hey, has anyone noticed that Shpeck straight up doesn't work with Foobar2000 version 2.0, even on the 32-bit version? Am i going to have to stay on version 1.6.16 forever? Because I am not giving up milkdrop!
It is just not showing up at all under foobar v2.0. Does anyone know how to fix this?
If I try to add it back into the components folder, it gives me an error that says "a component is broken" or something. So is it impossible to use certain older components with foobar v2.0? if so, I'm never upgrading............
Re: foo_vis_shpeck
Reply #835
I looked at this, but it seems to only be a standalone app. I don't see any way to integrate it into foobar with Shpeck? Do you know how?
Re: foo_vis_shpeck
Reply #836
I got it. Nevermind. Sorry to clutter the comments. For anyone else having this issue, you have to manually install it again from the "components" section in the UI.
Re: foo_vis_shpeck
Reply #838
As said: moved entirely onto other things.
Expression parser will need a complete rewrite. It uses x86 assembly extensively. Would be better to rewrite for DX11 while at it.
Re: foo_vis_shpeck
Reply #839
my entire kingdom for a 64-bit/2.x port of this...
Re: foo_vis_shpeck
Reply #840
Use showcwt, anything other is a toy.
Re: foo_vis_shpeck
Reply #841
However, making something like this for x64 version of foobar2000 probably requires having this visualization being actually done in a separate process (which means a total rewrite of this component right?) much like foo_dsp_vst3 AFAIK a Winamp visualization is 32-bit (correct me if I'm wrong) so it won't work if done in-process (as a 64-bit process can't load 32-bit DLLs obviously) for 64-bit foobar2000
Re: foo_vis_shpeck
Reply #843
https://www.foobar2000.org/components/view/foo_vis_milk2
Yeah, but what about AVS, Classic Spectrum Analyzer, and even SoundSpectrum visualizations (e.g. G-Force and WhiteCap)? Considering I think making shpeck into 64-bit foobar2000 requires it to have actual visualization done in an entirely separate process (much like VST 2.x/3.x Adapter) right?
BTW, I don't post or comment that much on this thread because I'm interested in proper audio analysis type visualizations like spectrum analyzers, spectrograms, oscilloscopes, peak and RMS meters unlike @TRCTheRaul
Re: foo_vis_shpeck
Reply #844
Proper audio analysis have full resolution at log2 frequency scale. But here I find amateurs coding plugins with low and quantized output only. Hard to learn here anything new.
Re: foo_vis_shpeck
Reply #845
Yeah but this low-quality (quantized) output is the result of the limitations imposed by API of some other media players like Winamp and even Windows Media Player, in which only 8-bit samples are provided for visualization, which doesn't accurately represent much quieter signals
Sure, since foobar2000's visualization streams already provide full-resolution PCM data (same bitdepth and samplerate as the source signal to analyze) for visualization effects, I'd imagine that foo_vis_milk2 could skip the quantization to 8-bit integer process (which also removes the wrap-around effect when samples exceed 0dBFS since you're actually dealing with floating point samples) to display more accurate waveform and spectrum data but that would still be pointless for audio analysis (same goes for SoundSpectrum visualizations like WhiteCap)
