Topic: Foobar Gallery (Read 1804207 times) previous topic - next topic
Foobar Gallery
Reply #700
Still trying to figure out if I like this colour config i came up with or not...
$puts(theme_dark,0)
// foreground colors
$puts(standard_color,$rgb(46,46,46))
$puts(special_color,$rgb(81,101,133))
$puts(playing_color,$rgb(208,237,255))
$puts(borders_color,$rgb(138,163,183))
// background colors
$puts(bg_color,$rgb(247,244,241))
$puts(bg_color2,$rgb(235,232,227))
// various symbols used in display
$puts(symbol_seperator,' • ')
$puts(symbol_rating,⋆ )
Foobar Gallery
Reply #701
oops....
Foobar Gallery
Reply #702
Hint towards those posting Navigator color-schemes:
If you additionally post them in the navigator-thread, then they may be included into future versions. I don't have the time to keep track of color-schemes posted in the gallery-thread, so only schemes which are posted in the navigator-thread will be in the pool for inclusion into future versions.
@hedge:
Sorry to be the messenger of bad news, but 1.2.1 was additionally released in a -minimal- variant optimized for faster playlist-scrolling - with tag-guessing and other stuff removed - so you probably did some work which you could have gotten for free *g*
- Lyx
Foobar Gallery
Reply #703
@hedge:
- Lyx
[a href="index.php?act=findpost&pid=290584"][{POST_SNAPBACK}][/a]
Ah well, i just took the 1.2.1 file, and fiddled and removed till I was happy. I would have had to do some stuff to the optimized variant anyway, and deleting tag guessing only took 30 seconds cos of the good structure of ya code
Foobar Gallery
Reply #704
OK, you all might think this is a silly question, but I haven't seen any answers in the forum or on the wiki:
How do you get your artists/albums columns to show the name of the artist/album only once?  It's been driving me nuts!
Foobar Gallery
Reply #705
These configs check the %tracknumber% tag. If it is 1, it displays %artist%, if it is 2, it displays %album% - and so on. It works but isn't that beautiful to my eyes.
[a href="index.php?act=findpost&pid=290669"][{POST_SNAPBACK}][/a]
Foobar Gallery
Reply #706
Example:
$select(%tracknumber%,%artist%,%album%,%date%)
Foobar Gallery
Reply #707
Example:
My latest shots:
[a href="http://i4.photobucket.com/albums/y134/rapsodie/Foobar2000%20Screenshots/fooshot1504file.png]File Mode[/url]
Album Mode
It's still not as tricked-out as some others I've seen on here ... but it still does everything I want it to do!  ;-)
Foobar Gallery
Reply #708
Masahiko, which font are you using? i like tahoma but your looks less "aliased"
[a href="index.php?act=findpost&pid=289907"][{POST_SNAPBACK}][/a]
I'm using Frutiver Linotype, 7pt, bold with clear type anti-aliased.
(i'm in late, sorry  )
Foobar Gallery
Reply #709
probably the last place people think of adding useless info to...
for those who want to save a little time...
Artist:  %ARTIST%$char(10)
Album: %album%$char(10)
Track:  %tracknumber%$char(10)
Title:    %title%$char(10)
%__bitrate%Kbps$if($stricmp(%__codec%,mp3),$if($stricmp(%__extrainfo%,vbr), VBR, CBR)) %__Codec%
- sig removed, no code allowed
Foobar Gallery
Reply #710
[a href="index.php?act=findpost&pid=291233"][{POST_SNAPBACK}][/a]
Which component is that?
Edit:  Nevermind.  Its under Display->Title Formating then under the System Tray tab.
Foobar Gallery
Reply #711
i should also mention that little box has a character limit so here is the code to help cut down on problems with the character limit
Artist:  $iflonger(%artist%,25,$trim($cut(%artist%,$sub(25,3)))...,%artist%)$char(10)
Album: $iflonger(%album%,25,$trim($cut(%album%,$sub(25,3)))...,%album%)$char(10)
Title:    $iflonger(%title%,25,$trim($cut(%title%,$sub(25,3)))...,%title%)$char(10)
here is what it looks like...
Foobar Gallery
Reply #712
[a href="index.php?act=findpost&pid=291009"][{POST_SNAPBACK}][/a]
Thanks =)
By the way, my current foobie:
[a href="http://img202.echo.cx/img202/5955/20050417foobie6nc.png][/url]
Foobar Gallery
Reply #713
My foobar is a slightly modified Navigation-Suite by Lyx.
(I have added some simple things like the vorbis version, the parenthesis color etc)
MyFoobar
Foobar Gallery
Reply #714
Example:
My latest shots:
Album Mode
[a href="index.php?act=findpost&pid=290877"][{POST_SNAPBACK}][/a]
Can you post your formating strings?
Foobar Gallery
Reply #715
[a href="index.php?act=findpost&pid=291772"][{POST_SNAPBACK}][/a]
Sure.    Is there a particular trick or section you wanted to figure out?
Foobar Gallery
Reply #716
[a href="http://img253.echo.cx/my.php?image=neoshooter16dj.jpg" target="_blank"]
After silence, that which comes nearest to expressing the inexpressible is music.
Foobar Gallery
Reply #717
I am working on this part:
Foobar Gallery
Reply #718
[a href="index.php?act=findpost&pid=291889"][{POST_SNAPBACK}][/a]
Here's what I did:
In the Display tab under the Artist column:
$select(%tracknumber%,%artist%)
In the Display tab under the Album column:
$select(%tracknumber%,%album%,%label% '('%date%')')
Any probs, PM me.
Foobar Gallery
Reply #719
How do you get alternating colors for the rows.  A great example would be iTunes' pattern of blue and white.
Foobar Gallery
Reply #720
Boom.
Foobar Gallery
Reply #721
Boom.
[a href="index.php?act=findpost&pid=292020"][{POST_SNAPBACK}][/a]
Excellent color scheme.
How did you get the alternating colors for each individual row?
Foobar Gallery
Reply #722
Boom.
Nice one! BTW what is the variable u used to get the '-ape' info @ bitrate (in the track info panel). May I have the script?
Foobar Gallery
Reply #723
[a href="index.php?act=findpost&pid=292023"][{POST_SNAPBACK}][/a]
i'm not entirely sure how it's done, but i have the jist of it.  you'll have to use the $mod() function in the color tab of your column. something like:
$ifgreater($mod(%_playlist_number%,2),0,[color a],[color b])
i probably left something out, because i'm a dolt, but that might work.
Foobar Gallery
Reply #724
Minimalistic
[a href="http://img255.echo.cx/my.php?image=foobar0gk.png" target="_blank"]
God Bless U.S.A
