If you can find where this config was downloaded, I can help you out with removing that panel and moving the rest of your stuff up. It looks fairly easy.
Alternatly, if you can right click on the config (in a 'background' area, such as between the panels) and click settings and post the code you see, that should contain what I need to help you out. However, I'd like to give this config a test run myself ;p.
// Global
$puts(width,$eval($get(albumwidth) + 4))
$ifgreater($getpvar(panel_1),1,
$puts(yoffset,15)
$puts(yoffset,$eval($get(width) + 18))
$puts(yoffset2,$eval($get(width) + 18))
$setpvar(tinyview,WINDOWSIZE:$eval($get(width) + 22):137:LEFT:TOP)
$setpvar(compactview,WINDOWSIZE:$eval($get(width) + 22):$eval($get(width) + 140):LEFT:TOP)
$setpvar(fullview,WINDOWSIZE:$eval($get(width) + 22):$get(fullheight):LEFT:TOP)
$setpvar(libraryview,WINDOWSIZE:$get(fullwidth):$get(fullheight):LEFT:TOP)
// Background
$drawrect(0,0,0,0,brushcolor-$get(background2) pencolor-$get(outline3))
$drawrect(0,0,0,4,brushcolor-$get(outline3) pencolor-null)
$drawrect(0,$eval(%_height% - 4),0,4,brushcolor-$get(outline3) pencolor-null)
// PerTrack
$select($eval($getpvar(layout) + 1),
$select($eval($getpvar(panel_1) + 1),
$panel(album art,Track Display,11,14,$get(width),$get(width),)
$drawrect(11,14,$get(width),$eval($get(yoffset) - 69),brushcolor-$get(outline1) pencolor-$get(outline2))
$panel(album list,Album list,12,16,$eval($get(width) - 2),$eval($get(yoffset) - 73),)
$panel(playlist order,Track Display,$eval({$get(width) + 22 - 254} / 2),$eval($get(yoffset) - 44),254,14,)
$select($eval($get(volume) + 1),
$panel(volume2,Volume,$eval({{$get(width) + 22 - 254} / 2} + 186),$eval($get(yoffset) - 44),68,14,)
$drawrect(11,$eval($get(yoffset) - 20),$get(width),91,brushcolor-$get(outline1) pencolor-$get(outline2))
$panel(playlist switcher,Playlist switcher,12,$eval($get(yoffset) - 18),$eval($get(width) - 2),65,)
$panel(quicksearch,Quick Search Toolbar,12,$eval($get(yoffset) + 47),$eval($get(width) - 2),22,)
$ifequal($getpvar(panel_1),1,
$panel(now playing,Track Display,11,$get(yoffset),$get(width),71,)
$select($eval($get(progress) + 1),
$panel($get(seekbar),WSH panel,$eval({$get(width) + 22 - 148} / 2),$eval($get(yoffset)+ 66),148,4,)
$panel(toolbar,Track Display,$eval({$get(width) + 22 - 226} / 2),$eval($get(yoffset) + 81),226,14,)
$ifgreater($getpvar(panel_2),1,
$drawrect(1,$eval($get(yoffset) + 118),$eval(%_width% - 2),4,brushcolor-$get(outline3) pencolor-null)
$drawrect(1,$eval($get(yoffset) + 122),$eval(%_width% - 2),$eval(%_height% - $get(yoffset) - 126),brushcolor-$get(background) pencolor-null)
$select($eval($getpvar(panel_2) + 1),
$panel($get(scpl),Single Column Playlist,11,$eval($get(yoffset) + 132),$get(width),$eval(%_height%- $get(yoffset) - 146),)
$select($eval($get(lyrics) + 1),
$panel(lyrics,Track Display,11,$eval($get(yoffset) + 132),$get(width),$eval(%_height%- $get(yoffset) - 146),)
$panel(lyrics2,Lyric Show,11,$eval($get(yoffset) + 132),$get(width),$eval(%_height%- $get(yoffset) - 146),)
$panel($get(spectrum),Egoh Spectrum analyser,1,$eval($get(yoffset) + 105),$eval(%_width% - 2),13,)
$panel(now playing,Track Display,11,$get(yoffset2),$get(width),71,)
$panel($get(seekbar),WSH panel,$eval({$get(width) + 22 - 148} / 2),$eval($get(yoffset2)+ 66),148,4,)
$panel(toolbar,Track Display,$eval({$get(width) + 22 - 226} / 2),$eval($get(yoffset2) + 81),226,14,)
$select($eval($getpvar(panel_3) + 1),
$drawrect(11,$eval($get(yoffset2) + 105),$get(width),$eval(%_height% - $get(yoffset2) - 244),brushcolor-$get(outline1) pencolor-$get(outline2))
$panel(album list,Album list,12,$eval($get(yoffset2) + 107),$eval($get(width) - 2),$eval(%_height% - $get(yoffset) - 248),)
$panel(playlist order,Track Display,$eval({$get(width) + 22 - 254} / 2),$eval(%_height% - 129),254,14,)
$panel(volume2,Volume,$eval({{$get(width) + 22 - 254} / 2} + 186),$eval(%_height% - 129),68,14,)
$drawrect(11,$eval(%_height% - 105),$get(width),91,brushcolor-$get(outline1) pencolor-$get(outline2))
$panel(playlist switcher,Playlist switcher,12,$eval(%_height% - 103),$eval($get(width) - 2),65,)
$panel(quicksearch,Quick Search Toolbar,12,$eval(%_height% - 38),$eval($get(width) - 2),22,)
$drawrect(11,$eval($get(yoffset2) + 105),$get(width),$eval(%_height% - $get(yoffset2) - 119),brushcolor-$get(outline1) pencolor-$get(outline2))
$drawrect(12,$eval($get(yoffset2) + 107),$eval($get(width) - 2),$eval(%_height% - $get(yoffset2) - 123),brushcolor-$get(background) pencolor-null)
$panel(lyrics,Track Display,22,$eval($get(yoffset2) + 117),$eval($get(width) - 22),$eval(%_height% - $get(yoffset2) - 143),)
$panel(lyrics2,Lyric Show,22,$eval($get(yoffset2) + 117),$eval($get(width) - 22),$eval(%_height% - $get(yoffset2) - 143),)
$drawrect($eval($get(width) + 21),0,1,0,brushcolor-$get(outline3) pencolor-null)
$drawrect($eval($get(width) + 22),4,$eval(%_width% - $get(width) - 23),$eval(%_height% - 8),brushcolor-$get(background) pencolor-null)
$panel($get(scpl),Single Column Playlist,$eval($get(width) + 32),14,$eval(%_width% - $get(width) - 43),$eval(%_height% - 73),)
$drawrect($eval($get(width) + 32),$eval(%_height% - 49),$eval(%_width% - $get(width) - 43),35,brushcolor-$get(outline1) pencolor-$get(outline2))
$panel($get(spectrum2),Egoh Spectrum analyser,$eval($get(width) + 33),$eval(%_height% - 47),$eval(%_width% - $get(width) - 45),31,)
theres the code from right clicking the area i want removed.
as for where i got the config. i was sent it by a friend, so im not sure.
i was just searching through the boards here and i cannot find it anywhere... ill check if theres any readme located somewhere in my foobar folder that may give me a hint as to where it is
cant find a URL or anything, but the readme says this:
layout: gsm_flavored_mod
author: jclim00
hopefully thatll help you find it.
