Topic: Help with a titleformat script to find any album with Rateyourmusic (Read 1367 times) previous topic - next topic
Hey all, trying to make a script that's a foolproof as possible that can link to albums on Rateyourmusic.com to use in conjunction with my "Run Command..." plugin.
Currently I have this
"https://rateyourmusic.com/release/album/$lower($replace(%album artist%, ,_))/$lower($replace(%album%, ,_))"
However, Rateyourmusic's URLs don't like any kinds of punctuation, so no commas, periods, apostrophes, colons, etc. It's ok with dashes though...
Example: https://rateyourmusic.com/release/album/deaths-dynamic-shroud_wmv/endless-vi-void-complex/
Additionally RYM also adds a part to the link if the album is actually an EP, example: https://rateyourmusic.com/release/ep/stellardrive/ers-2/
I do have this info stored in my files as well with %MUSICBRAINZ_ALBUMTYPE% which will tag the field with "EP" if it is.
All this is to say... I am way too dumb with Title Formatting to make an end all be all script that will work MOST of the time (I realize there will probably be corner cases where it still won't work just because RYM's linking is kinda picky) when trying to easily link to an album for review/research purposes.
Would any of the title format whizzes here be able to help me out? Would be much appreciated.
Re: Help with a titleformat script to find any album with Rateyourmusic
I've been using this for ages:
https://rateyourmusic.com/release/album/$lower($replace($ascii(%artist%),!,_,.,_,$char(32),_,&,and,é,e,à,a,è,e,á,a,$char(40),_,$char(41),_,-,_,$char(39),))/$lower($replace($ascii(%album%),!,_,.,_,$char(32),_,&,and,é,e,à,a,è,e,á,a,$char(40),_,$char(41),_,-,_,$char(39),))
However, RYM url's aren't consistent so this won't always work. If an artist name is more than a single word, separation is either _ or - although most url's use _ but newer artists all tend to use - to separate words in url's.
Thank you! Better than nothing!
For the "album or ep" part of the URL, you could test the MB field you have tagged for whether it contains "EP" -
$if($strstr(%MUSICBRAINZ_ALBUMTYPE%,EP),ep,album)
So including that -
https://rateyourmusic.com/release/$if($strstr(%MUSICBRAINZ_ALBUMTYPE%,EP),ep,album)/ ...
... followed by the rest of the URL code posted above.
(Mind you I have not tested this, but theoretically it should put "ep" in the URL when tagged, and if not "album")
