Topic: foobar2000 always crashing when exiting (Read 1603 times) previous topic - next topic
So this issue seems to be prevalent with my foobar2000 install and I am not sure what's exactly causing this. Every time I hit the X button to close foobar2000 it seemingly quits but I later get a popup saying foobar2000 crashed.
I've uploaded the crash log on pastebin: https://pastebin.com/aZWzw98Y
attached a dump file as well which came along with it.
This reddit post seems very similar to my situation as well but not sure what happened after that.
https://www.reddit.com/r/foobar2000/comments/cv6zwl/foobar_crash_on_exit/
Re: foobar2000 always crashing when exiting
Crash log is pointing at Spider Monkey Panel.
I guess I have to completely remove them if I want further support? Currently I'm running 2 spider monkey panels, Library Tree and Biography.
Your 3rdparty components are too old.
Are you using CD Art Display (foo_cad) or something?
I think you should clean it up a bit.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Oh no, I imported this skin from a reddit post but the creator was using a lot older install of foobar2000.
Try moving the old, unused components to your desktop.
Thanks, I'll try removing them and see if anything can be done to resolve Spider Monkey Panels. Will monitor the situation for now.
