Topic: Album split (Read 728 times) previous topic - next topic
Album split
For years I'm using Foobar Mobile (1.3.1 724). Due to space limitations I transcode to MP3 using a playlist.
As my sister gifted me a 1 TB micro SD, no need for transcoding anymore so I simply sync all my FLAC's to the SD.
Much to my surprise, I had a couple of albums split.
Normally an album is considered an album when both ALBUMARTIST and ALBUM are identical.
The first split I could solve, I paste the tags in Excel and compare them
  ALBUM = Brahms,J - Op.1 - Piano Sonata No.1      ALBUM = Brahms,J - Op.1 - Piano Sonata No.1   0
Excel thought them different and indeed one Album ended with a tab.
So Foobar is right and my tagging inconsisten but Foobar is also a bit severe as I simply don't have this problem using other media players.
Maybe trim trailing and leading spaces and tabs?
This one I couldn't solve
  ALBUMARTIST = Rittner     ALBUMARTIST = Rittner   1
  ALBUM ARTIST = Rittner     ALBUM ARTIST = Rittner   1
  ALBUM = Brahms,J - Op.76 - Piano Klavierstücke     ALBUM = Brahms,J - Op.76 - Piano Klavierstücke   1
Both ALBUM and ALBUMARTIST are identical, still Foobar split the album.
Does Foobar uses other criteria to determine if tracks belong to an album?
Both tracks are in the same folder.
Vorbis Comment Block (1019 bytes):   Vorbis Comment Block (1049 bytes):   0
  Vendor String = S     Vendor String = S   1
  TRACKTOTAL = 27     TRACKTOTAL = 27   1
  TRACKCOUNT = 0     TRACKCOUNT = 0   1
  CDCOUNT = 0     CDCOUNT = 0   1
  MCHI_YEAR = 1878     MCHI_YEAR = 1878   1
  PEOPLE = Rittner, Hardy [Piano]     PEOPLE = Rittner, Hardy [Piano]   1
  REPLAYGAIN_TRACK_GAIN = +0.36 dB     REPLAYGAIN_TRACK_GAIN = +7.00 dB   0
  DISCNUMBER = 0     DISCNUMBER = 0   1
  VOLUME LEVEL (R128) = -4,642819881439209     VOLUME LEVEL (R128) = 2,0047500133514404   0
  NUMBER PLAYS = 18     NUMBER PLAYS = 9   0
  WORK_YEAR = 1878     WORK_YEAR = 1878   1
  PHONE = 1     PHONE = 1   1
  MCHI_OPUS = Op.76     MCHI_OPUS = Op.76   1
  DYNAMIC RANGE (DR) = 12     DYNAMIC RANGE (DR) = 12   1
  COMPOSITION = Piano Klavierstücke Op.76     COMPOSITION = Piano Klavierstücke Op.76   1
  GENRE = Solo     GENRE = Solo   1
  TRACKNUMBER = 7     TRACKNUMBER = 8   0
  MOVEMENT = 5. Capriccio. Agitato     MOVEMENT = 6. Intermezzo. Andante con moto   0
  OPUS = Op.76     OPUS = Op.76   1
  ARTIST = Rittner, Hardy [Piano]     ARTIST = Rittner, Hardy [Piano]   1
  DATEIN = 41275     DATEIN = 41275   1
  PEAK LEVEL (R128) = -1,6 dBTP; -1,6 Left; -1,8 Right     PEAK LEVEL (R128) = -8,9 dBTP; -8,9 Left; -10,0 Right   0
  BPM = 116     BPM = 86   0
  DYNAMIC RANGE (R128) = 14,2069501876831055     DYNAMIC RANGE (R128) = 11,5146903991699219   0
  GROUPING = Piano Klavierstücke Op.76 (1878)     GROUPING = Piano Klavierstücke Op.76 (1878)   1
  WORK = Piano Klavierstücke Op.76     WORK = Piano Klavierstücke Op.76   1
  COMPOSER = Brahms, Johannes (1833-1897)     COMPOSER = Brahms, Johannes (1833-1897)   1
  EPOQUE = (08) Romantic     EPOQUE = (08) Romantic   1
  INSTRUMENT = Piano     INSTRUMENT = Piano   1
  VOLUME LEVEL (REPLAYGAIN) = 0,3571799993515015     VOLUME LEVEL (REPLAYGAIN) = 7,0047497749328613   0
  SERIES = BrahmsJ_Op.76     SERIES = BrahmsJ_Op.76   1
  COMMENT = Op.76 - V. Capriccio. Agitato     COMMENT = Op.76 - VI. Intermezzo. Andante con moto   0
  DATE = 2013     DATE = 2013   1
  TITLE = 5. Capriccio. Agitato     TITLE = 6. Intermezzo. Andante con moto   0
TheWellTemperedComputer.com
Re: Album split
I don’t see the release YEAR tag compared between the two files, do you have that filled in differently between these two tracks? I’m not sure for Foobar mobile, but some players use AlbumArtist/Album/Year for splitting albums.
Sometimes I have found the only way to have an album correctly combined when this happens is to remove the album from the card, update the library, then add the folder back and update again. I have had the same issue a handful of times on Android. Strangely enough I don’t actually recall the same happening on my iPhone though.
Re: Album split
This is how JRiver display the tags.
DATE is the year of the release and is identical in both cases.
Thank for the suggestion anyway.
