Topic: Eole, a SMP/ColumnUI theme (Read 55944 times) previous topic - next topic
Re: Eole, a SMP/ColumnUI theme
Reply #250
Hi @Ottodix I absolutely love your Eole theme - i've been looking for a comfy, sleek dark theme with all the utilities and tools I want for ages and so far Eole is possibly the best I've found. The only issue I have with it is that all the context menus from right clicking are still white/grey rather than turn dark when I change the theme colour. Is there any way I can change this to make the menus dark?
Reply #251
Hi @Ottodix Is there any way I can change this to make the menus dark?
Hi! And thanks for the nice words.
Nope, you can't. Probably with foobar v2, you will be able to set foobar theme to dark and then have dark context menus, but I didn't test it, and eole probably won't work with foobar v2. I'm not in a hurry to test and do the required updates, other thinks on my plate
Reply #252
There should be no problems with it working in 32bit fb2k v2.
However, performance may take a hit and anything depending on the existence of foo_playcount / displaying ratings via script will probably be broken.
foo_playcount is obsolete in v2 and playback statistics are built in. So if you had clickable ratings that write file tags if foo_playcount is missing, that would always happen because the condition would always be false. But %rating% would not display content from file tags because playback statistics takes it over. You have to use %rating% for playback statistics and $meta(rating) for file tags. This applies to everyone who may not have a clue what foo_playcount did previously as it's now global whether you like it or not.
Reply #253
Ok, thanks. If it's just a matter of %rating% vs $meta(rating), it's quite easy to change.
"performance may take a hit". Globally? Why that? Is there a specific mecanism/feature of v1.6 which will be slow on v2?
Reply #254
Sorry I should have been clearer. It's basically iterating large handle lists / title formatting that is going to be slower. It shouldn't effect anything else.
Although these SDK release releases are for developers, they kind of apply to script authors too (metadb_v2 section).
https://wiki.hydrogenaud.io/index.php?title=Foobar2000:Development:SDK_2022-08-10_Release_Notes#metadb_v2
Reply #255
Ok, thanks, it's much clearer
Reply #256
For the Playlists view, I've changed the first filter from Genres to Composers, including the "Label" field, yet "Genres..." still shows in the title/search bar at the top of the column. I did the same thing in the Library view, but there, "Composers" does show up in the dropdown menu and title field once selected from the menu. Is there any way to get the desired label to show up in Playlists?
Reply #258
Is there any way to show embed arts like back, artist and cd besides front on 'now playing' tab?
Reply #259
Hello.
First off, I really appreciate your hard work. Eloe is really awesome looking skin. But I found it makes Foobar to launch very slow. Every time I launch it, it takes around 20 sec. Before I installed Eloe, it was opened immediately. Of course, I understand it could be the both side of the edge. As I have tons of songs in my hard drive, it causes the problem.
However, I'd like to ask you if there is a way to reduce the loading time.
Thank you again!
Reply #260
yes,
in FB2K v2.0 32bit,the rating is not working
Reply #261
Is there a way to add 1 more layout to the rigft side panel? (Hide/show track infos)
Reply #262
Hi guys, sorry for the english!
I always use the ''Eole'' theme and I'm always in the ''Library'' tab.
Is there a way in the right panel (Right playlist) of the "Library" tab to show the image of the currently playing song file, and to change it every 5 seconds, just like it does in the "Play Now" tab?
https://imgur.com/a/Xu11euj
Reply #263
Hi, I just updated to the latest version. It's very good, but I have a small problem that I am not able to solve. In the tracklist, the image of the cover (attached image) is too small for me. Is there a way to make it bigger? In previous versions it was able, but now I can't.
Thank you. Regards
X
Reply #264
Thank you. Regards
[attach type=thumb]24508[/attach]
Forget it, I'm so stupid. I find it :D
