Topic: Program for bit-comparing files? (Read 2548 times) previous topic - next topic
Let's say I want to bit-compare two programs written in C++, what should I do? Are there any free programs which do this?
I understand that if I calculate checksums for the 2 programs and if both have the same checksum, then they're the same, is this correct?
In a command-prompt you use the command fc [file1] [file2].
And yes. They should be identical if the checksum is.
You forgot /b. The line should read:
fc /b file1.bin file2.bin
use win SQL
wonderful!!!!!!!!!!
vondafone!!!!!!!!!!
vodafone!!!!!!!!!!!!
