Topic: Ivan & Menno frontend "runtime error 380" (Read 3848 times) previous topic - next topic
Has anyone of you using the Ivan&Menno frontend got the error message "runtime error 380 - invalid property value"?
nosync (...thats my Maxi Studio ISIS refusing to sync multitrack recording...)
Nosync, I just got that same error message when trying out a new version of one of my other frontends. I did something that was 'not allowed'. What exactly did you do to get the error message?
The first time I used the frontend everything was OK, but the second was when the message occurred. As a matter of fact I read about the vb-runtime problem on the webpage before I used it, so I expected the worst but even so it worked fine once (WinMe). Right now I´ve downloaded the vb-runtime sp twice, just to be sure that the exe wasn´t corrupted, but still no luck. I tried to take a look in the registry to see if there was something there that could point me in the right direction, but you know, it´s a jungle in there.
I got runtime error 380 also. I then deleted the both the program and the cfg file and whatnot and reextracted it. Voila! Success
