Topic: Psytel AAC encoder 3.01 (Read 4231 times) previous topic - next topic
Psytel aac encoder version 3.01 is released
- Main profile fixed (should result in increased Quality/bitrate)
- Better block size switching (less pre-echo artifacts)
- Support input of 24bit int and 32bit float
- Few bug fixes
- Experimental AC3 -> AAC 5.1 Direct transcoding based on A52(consider this very beta)
The new block swithing method is co-developed by "Ivan" and a Urkranium audio scientist named "loof slirpa"
The binaries can be found here
http://www.psytel-research.co.yu/binaries/loof-slirpa
Sven Bent - Denmark
Hi sven this link is no work... You tested this enc????:confused:
read the last part backwards...
yes i tested this and i can tell so far that the AC3 to aac encoding is faulty.
There is something wrong with the back channels
Using azid and encoding tih aacenc does not have this artifact.
However the Generel quality seems somehow lower.
maybe ivan is duing some magic in his encoder for not losing quality due to transcoding.
He just need to fix the back channels issue.
[edit]
spamh and fatboyt compressed much better now around 30-40kbits smaller and sligthly better quality
Sven Bent - Denmark
Doooooohhhhh
April First.
 Hahahahaha 1st april is super i trust it..........
At least, Sven didn't post as a news thread.
oohh and now you ruined the surprise
Ýou could have waited until tommorow..just to se how many wouldn't have figured it out
Funny parts  is that i made the exact same joke last year at vqf.com
so..there is no psytel AAC encoder 3.01..yet
but damn it had some nice improvements
Sven Bent - Denmark
Psytel AACenc 3.01 has CD quality at 20kbps!!!
I tested it! It's true!
P4n05 said so.
Hi This Enc very slow!!! 0,5x my athlon 950Mhz.
Thanks for youre received binary in my e-mail...
And my winamp crash in 1 minute track playing this file.I tested old winamp binary based on FAAD 0.6 and works fine.
