51
3rd Party Plugins - (fb2k) / Re: External Tags
Last post by Defender -I use "Ape tags, write stream tags to SQLite, read all three tag types" (not Only Ape). If I tag local *.m2ts file the tag is created in the folder conaining that m2ts audio file. That is great. If I create a tag for radio stream - does it go to the "external-tags" file?I run a normal item in VU meter and adjust the level so it is more or less at 0db.
What would be the best way to find proper peak in radio stream? If it can't be measured should I guess/estimate it from the graphic peakmeter by eye or measure with external dB meter (installed on the phone)?
Then I switch to a stream and adjust values I write manually until it is more or less the same on the VU meter.
Bit tedious and quite unfortunate that there is not an automatic tool to do this.
I understand it cannot be scanned with a normal scanner that needs a 'track' to end at some time, but if a scanner was adjusted so that you can interrupt it manually after a certain time and it writes the values measured until that moment that would be great. It doesn't have to be that exact, but I don't want to go deaf when switching to a stream.
Scanner could be made so that this feature is only available on streams (http(s)://).
I'm not looking forward to manually add values for 200 different streams
