Topic: Start play Automatically (Read 1014 times) previous topic - next topic
Hello,
I have already added a entry like: http://192.168.1.54:50082/stream/swyh.mp3 and i hear what i need.
Questions:
1) Can Foobar, when it is loaded, start automatically the up entry ? yes !solved with :Configure--playback---save playback state.... on !
2) How I can load Foobar MINIMIZED AS ICO with a dos batch? Or load it with Windows as minimized ?
Thanks very much !
Re: Start play Automatically
Use command line switch -
foobar2000.exe /hide
Note: it loads to the system tray if you have 'Minimize hides, close exits' selected in Preferences > Display > Default UI > Background and Notifications.
Thanks vey much ! Checked it : i'm happy !
However i'm corius about:
As User UI i see only (see attached) "Default UI
Again thanks !
