Topic: Decoding failure on delete (recycle) (Read 631 times) previous topic - next topic
Can we avoid displaying the message Decoding failure at x:xx.xxx (Object not found): whilst recycling a file as it's currently playing?
Ideally silently skip to the next file in the playlist instead, using 1.4b1.
Re: Decoding failure on delete (recycle)
It probably should stop playback, at the very least. Or, as you suggested, skip to the next playable track.
Good find, it's an actual v1.4 regression from the v1.3 series. It will be fixed, thanks for reporting.
