aoTuV pre-beta 5 released!
Reply #109 – 2006-07-23 06:09:35
It doesn't seem wise to force higher lowpass at these bitrates. Almost certainly you are hurting quality. IMO resampling is much more aggressive than lowpassing at these bitrates. I don't seem to be as sensitive to minor artifacts/differences than some people.. that or I just don't care. How is resampling more agressive than lowpassing? I don't quite follow.With aoTuV predefined low q values are already tuned by aoyumi in a very competent manner as already proved by listening tests. Almost... some of the illogical things from libvorbis still remain. use "-q 0 --resample 40000" and "-q 1 --resample 39999" and you will see/hear what I mean (I mentioned this 'issue' before in this very thread). Logic should tell you that 1 sample per second shouldn't make any noticable difference. After that try "-q 0 --resample 39999 --advanced-encode-option lowpass_frequency=15".. the bitrate should be pretty close to the 40000hz encode.Is your lowpass dislike based on listening tests? If it is I'd like to see ABX/ABC-HR tests results proving that resampling is better than lowpassing... I never said it was 'better', I said I prefer it. It's probably due to the assumption that 'lower samplerate' = 'less data to code' which implies that you save some bits. Unfortunately, theory doesn't always work perfectly in practice. For example "-q -2 --resample 26000 --advanced-encode-option lowpass_frequency=99" and "-q -2 --resample 25999 --advanced-encode-option lowpass_frequency=99". These things drive me up a wall. Those rates are the threshold where vorbis switches from the 32khz settings to the 22khz settings (and the example above ^^ is another threshold where things suddenly change). So depending on what you prefer to hear, lowpassing a higher samplerate untill it approximates the bitrate of the lower samplerate might be the way to go, I honestly am unsure/undecided which is better for my ears. And my dislike for lowpass filters came about from 128kbps mp3s back in the days I was still a n00bie. I just got disappointed that there wasn't anything above 16khz (I can hear isolated noise up to ~21khz)... it's been a long journey.(of course I don't like lowpass filters so --advanced-encode-option lowpass_frequency=99 is always used ) Damn. I'm afraid to find out what that sounds like -q -2 --advanced-encode-option lowpass_frequency=99 ... if that doesn't get you screaming and covering your ears... It's better to know, then you don't have to guess/speculate.Yet, I cannot decide a release day. There is various change etc. and many tests are required. The way you put that, it sounds like it might be almost ready. I can't wait. [edit]spelling[/edit]
