Topic: JPEG Compression Comparison (Read 12514 times) previous topic - next topic
I did a little test on JPEG encoders yesterday, wanna find out how much the maximum quality of each encoder differ from the originals. I used ionForge imageDiff in comparing output files with original files. I'll post result here just in case someone might interest.
These are lists of programs and options I used in creating JPEG file.
ADOBE Photoshop CS2: Quality = 12, Baseline Optimized, Non-progressive
XnView 1.80: Quality = 100, Optimize Huffman table, Non-progressive
Advanced JPEG Compressor 4.6: Non-progressive, True Color (24 bit), High Precision (2 Luma : 2 Chroma), Compression Level 1 (both Luma and Chroma)
LEADTOOLS Command Line File Converter: /F10 (Output format = Jpeg File Interchange Format), /Q2 (Quality factor, values are in the range 2-255)
IrfanView 3.85: Quality = 100
ACDSee 7.0 Build 62: Image Quality = 100, Optimize Huffman codes, Color component sampling 2:1 Horizontal 2:1 Vertical, Never add/update thumbnails
JPEG Wizard 2.4.0.6: Subsampling = Color 1/1/1 - Favor Quality, Initial overall quality setting = 1 (Lum 0, Chrom 0), Baseline
Jasc Paint Shop Pro 9.01: Encoding Type = Standard encoding, Compression Factor = 1, Chroma Subsampling = YCbCr 1x1 1x1 1x1 (None)
Corel Photo-Paint 12.0.0.458: Encoding Method = Optimize, Compression = 0, Smoothing = 0, Sub Format = Optional (4:4:4)
The Gimp 2.2.8: Quality = 100, Optimize, Smoothing = 0, Subsampling = 1x1,1x1,1x1, DTC method = Floating-Point
Sample 1
Sample 2
Sample 3
*sample 1 & 2 are original files that I used on the test. original sample 3 is too big to host at imageshack, so this is 50% JPEG version.
Results
Results show differences in percentage of both pixel and colour, lower is better.
Well, what I got from the test are
- Advanced JPEG Compressor 4.6 produces JPEG file with least differences.
- The best 3, IMO, are The Gimp, Advanced JPEG Compressor, and Corel Photo-Paint.
- XnView and IrfanView use the same JPEG encoder.
- ACDSee has poor JPEG encoder. On 3 samples, It produce lower quality output than XnView and IrfanView, also larger file size.
...which happens to be the infamous Independent JPEG Library. It is optimized for multiplatform-ness, but not for quality.
- ACDSee has poor JPEG encoder.[{POST_SNAPBACK}][/a]
Intel JPEG Library version 1.1.2. Extremely optimized JPEG routines - by far the fastest encoder and decoder - but of course, quality is overlooked in favour of speed.
I would be very interested in results from Pegasus' JPEG Wizard:
[a href="http://www.jpg.com/jpegwizard.htm]http://www.jpg.com/jpegwizard.htm[/url]
Pegasus has lots of experience in JPEG encoding.
This is result from Pegasus' JPEG Wizard.
Setting: Subsampling = Color 1/1/1 - Favor Quality, Initial overall quality setting = 1 (Lum 0, Chrom 0), Baseline
It produces largest file size but no improvement in quality. ADOBE and Advanced JPEG Compressor are better.
How about Paint Shop Pro?
I once did a (purely visual) comparison of PSP JPG output vs. IrfanView output at the same quality, and i could see tiny differences, but i couldn't decide which was better or worse. IrfanView's files were a bit smaller, though.
Very interesting test. What was the methodology (what programs & functions did you use to get the percentages)? And what's the difference between pixel & color (pixel always has a color )?
yes, very interesting, but i don't get the results.
I updated results. add more 3 programs; Gimp, Corel Photo-Paint, and Jasc Paint Shop Pro. The result of The Gimp surprise me. It's the best in 2 of 3 samples and it's a free software.
I used [a href="http://www.ionforge.com/products/imagediff/]ionForge imageDiff[/url] to detect the differences.
ImageDiff can be used to
- comparing an original lossless image to a compressed lossy version
- comparing different implementations of the same format
- comparing color profiles.
- comparing antialiasing algorithms to see which is smoother.
- detecting any subtle change.
(take from  the program's help file)
[a href="index.php?act=findpost&pid=319918"][{POST_SNAPBACK}][/a]
Truely, I'm not really understand it neither.  Therefore, I'll ask this in ionforge's forum. To my understanding, this program just compares the difference of colour in each pixel and results in changed pixel percentage. (I test this by compare an original colour picture with a greyscale one. ImageDiff shows 100% difference in  pixel and 14.96% difference in colour  )
I think the test is kinda pointless, unless you compare the quality of same file size files. That would really say something about the quality of the encoder.
[a href="index.php?act=findpost&pid=320015"][{POST_SNAPBACK}][/a]
This is more like quality limitation test. It tells you what's the best you can get from each encoder.
[a href="index.php?act=findpost&pid=320054"][{POST_SNAPBACK}][/a]
Well, yeah, but usually you use JPG to get small filesize with acceptable quality. If you're shooting for pure quality, you go with PNG.
- The best 3, IMO, are The Gimp, Advanced JPEG Compressor, and Corel Photo-Paint.[a href="index.php?act=findpost&pid=319767"][{POST_SNAPBACK}][/a]
I think that one is pretty much a no-brainer, looking at the produced file sizes.
That doesn't excuse PSP and Pegasus' lame performance, though...
...which happens to be the infamous Independent JPEG Library. It is optimized for multiplatform-ness, but not for quality.[{POST_SNAPBACK}][/a]
I updated results. add more 3 programs; Gimp, Corel Photo-Paint, and Jasc Paint Shop Pro. The result of The Gimp surprise me. It's the best in 2 of 3 samples and it's a free software.[a href="index.php?act=findpost&pid=319997"][{POST_SNAPBACK}][/a]
[a href="http://packages.debian.org/unstable/graphics/gimp]http://packages.debian.org/unstable/graphics/gimp[/url]
http://packages.debian.org/unstable/libs/libjpeg62
Gimp2 depends on libjpeg62, the Independent JPEG Group's JPEG runtime library.
Isn't this just like using spectrograms to judge sound quality of lossy codecs?
[a href="index.php?act=findpost&pid=320161"][{POST_SNAPBACK}][/a]
No, using spectrograms to judge sound quality of lossy codecs is like using headphones to judge quality of JPEG encoders
Well, yes, though JPEG doesn't have any psycho-visual model, so you can take it from calculation point of view more than you do with lossy audio codecs.
When you compare all black picture with all white then you get both percentages 100%, so I guess you're right - pixel tells you how many pixels differ, and color tells you how much RGB values differ for given pixels.
If program A produces bigger file size  and more changed pixels than program B, can I say for sure that program A is worst than program B?
Well, yes, though JPEG doesn't have any psycho-visual model.
[a href="index.php?act=findpost&pid=320172"][{POST_SNAPBACK}][/a]
Define psychovisual model.
What do you think is the quantization matrix in JPEG for ?
maximizing PSNR != maximising visual perceived quality
Sebi
MPEG audio doesn't have any psychoacoustic model either.
Those standards do not define encoding models, only decoding process.
Some mpeg audio encoders can use psychoacoustic models, and some jpeg encoders can use psychovisual models.
Waa.. I made a mistake. I used wrong setting with ACDSee. I chose 4:2:0 chroma subsampling which can degread output quality. I tested again without subsampling. Results are identical to Pegasus JPEG Wizard with slightly increasing filesize.
ACDSee 7.0 Build 62 (without chroma subsampling)
Sample 1: pixel = 51.43 colour = 0.12 filesize = 1,279,584 bytes
Sample 2: pixel = 41.31 colour = 0.16 filesize = 262,337 bytes
Sample 3: pixel = 90.84 colour = 0.32 filesize = 1,711,977 bytes
ACDSee may use same JPEG encoder as JPEG Wizard.
Furthermore, Corel Photo-Paint also use IJP's JPEG library.
With this command-line, you can create the same output as Photo-Paint.
cjpeg -quality 100 -optimize -dct int -sample 1x1 -outfile <outfile.jpg> <infile>
Additionally, someone at ionforge explained about the changed colour percentage.
To clarify, the changed colour percentage data is the amount of color change per pixel. So as an example, if you have a 10x10 pixel image that is completely black (0x000000), and compare it against a 10x10 white image (0xFFFFFF), the color change would be 100%.
However, what is being calculated is the total amount of color per pixel (128+128+0, max 255+255+255=765), divided by the total amount of color in the comparison image.
So if every pixel in our 10x10 image above is exact middle gray, and it is compared against a perfectly white image, the color difference would be 50%. If a single pixel is gray instead, the % color difference would be .5% (1% / 2).
I think most encoders give similar quality. Some programs produce better results because they give more encoding options. If someone looking for a good free JPEG encoder, IJP's could be a choice. (If ony it would support png input.)
It would be interesting to calculate the % variation per byte or kilobyte, to see which encoder has best efficiency... At least at high file sizes.
It would really not be that hard to devise a blind test for images. What I'd be afraid of is that no JPEG quality option would really be indistinguishable from the original. IIRC, the last time I looked at such things in the Gimp, every quality setting caused a visible degredation.
[a href="index.php?act=findpost&pid=320178"][{POST_SNAPBACK}][/a]
For sure not. Just like you can imagine bigger lossy audio file to have more changed samples than smaller lossy file, but the bigger one still can sound more like the original.
I'd say that in this JPEG test the color percentage tells more about the quality than pixel percentage, it still would be good to see output images to be of more or less the same size.
[a href="index.php?act=findpost&pid=320207"][{POST_SNAPBACK}][/a]
Well it can be called a simple psycho-visual model.
My definition would be: Psychovisual model - something more complex and serving more complex purposes than quantization matrix in JPEG encoders
[a href="index.php?act=findpost&pid=319774"][{POST_SNAPBACK}][/a]
The problem with them that I've ran into is their jpeg encoder isn't supported or is non-compliant with many hardware dvd players that can display jpeg images. Also there's a few other image editing programs that refuse to open *.jpg images saved by them. At least they do have the option to save at a higher quality vs. the likes of MS Paint.
