Topic: Difficult samples for 1.2 beta at ~48 kbps (Read 7204 times) previous topic - next topic
Found a dozen of short samples, that sounds unpleasantly with new beta (NetRanger build from May 27) at 32-50 kbps range. There are some easily audible clicks and noises.
P.s. When i merge all samples into one file, seems like all artifacts gone (even on Casio MT-600 Blues Harmonica C4 part), excerpt for the first second of file.
Re: Difficult samples for 1.2 beta at ~48 kbps
Yeah, it is really a very noticeable problem, especially in some of the samples, like Alesis-Fusion-Viola-C5.1.2b.48k.opus
Just confirm this weird behaviour
If you're referring to the first 0.5 seconds of that file, then it's related to the speech/music detector that took a small amount of time to realize that the sample was music and not speech (so the first 0.44 seconds are encoded as speech). The good news is that it only happens at low bitrates and that for longer files it would only affect the beginning. That being said, Opus has a way to use up to two seconds of "look-ahead" to avoid this kind of issues. It's just a matter of getting the encoder to use it. I recently wrote a library (libopusenc) that actually makes it easy to encode Opus files and take advantage of that feature.
I thought that changing between these modes is transparent...
Is it possible to enable this mode in the opusenc.exe? Or maybe it is better to add some switch (--music) which will tell the encoder that it is definitely music and not speech. IMHO, it is even better to think that it is music by default, and --speech setting for changing this. As far as I remember, old versions of opusenc had such switches.
Usually they are, but sometimes it's not perfect, especially at low bitrate. I'm currently working on a patch that reduces artefacts on transitions by boosting the bitrate a bit.
It's on the TODO list. As I said, I have it implemented in libopusenc, but we need to switch opusenc over to libopusenc.
Also on the TODO list for opusenc.
Somehow everyone thinks what they're doing should be the default ;-) There's also a lot of people using Opus for podcasts and that sort of things. So the default will remain "auto-detect". And it's generally doing a decent job. It's only the very beginning of the files that had an issue -- and only at low bitrate
I could easily see in the near future opus being used in video games and apps for their audio files especially the ones the developers opted for vorbis  (like Pokémon Go and Mobius Final Fantasy). Resolving this issue might prove integral. I would never have noticed but for this topic.
"Video games" developers will likely have no problem tweeking the encoder in a way they need...
I heavily doubt they would even bother. I haven't come across a single game they did. For example every game that uses vorbis seems to use general settings and implementations. Even mp3so in Square Enix games use generic Lame encoders and settings, they even leave the ID3tags on them for everybody to see.
First, there *are* games already using Opus. In fact, there have been since before it was called Opus (it was CELT back then). Second, this issue can only happen at very low rates like 32-48 kb/s, whereas games tend to code at a much higher bitrate.
So it turns out there was *also* a bug involved here. While everything I said earlier is true and there can be an issue when at the beginning of files the encoder isn't sure between speech and music, it turns out that a bug was causing the encoder to be sure the signal is speech. With the fix applied (see git master), it still takes about 0.5 second for the encoder to be sure it's music, but in the mean time (with 50% probability), it actually chooses to use CELT, which is the right decision.
