Topic: Foobar2000 degradates Windows 10 security (Read 1824 times) previous topic - next topic
I have determined that foobar2000 needs to create a file named "running" in the same folder, where the foobar2000.exe is located. If the folder was "c:\program files\foobar200\", the user has to have a write/create file permissions on it. According to the Windows 10 security concept it is not recommend and would weaken the system security - even both explicit permission grant and/or executing as administrator. Such practice to make a program folder read-only is used also in UNIX/linux world, where process activity flags are created as a rule in /var.
So my proposal is to "teach" foobar2000 a little bit to the level of the modern programming culture.
It would be very compromizing if this good software was used as an entry gate for a malicious attack.
Re: Foobar2000 degradates Windows 10 security
Only when foobar2000 is in portable mode. Otherwise this file goes to %USERPROFILE%\AppData\Roaming\foobar2000
It's a bad idea to put portable programs into "Program Files" folder.
This has been the case since Vista came out over 10 years ago. You have some catching up to do.
I know the installer didn't let you place your portable folder in program files because it won't let you without admin rights. Therefore you must have let it install elsewhere and then moved it manually.
Thanks a lot.
It seems to be a good idea to resolution.
It is my knowledge gap in portable apps programming traditions.
