Topic: Inconsistent Sensor Readings with PIC16F877A and DHT22 (Read 2493 times) previous topic - next topic
I'm working on a project with a PIC16F877A microcontroller and a DHT22 sensor, but I'm getting inconsistent readings. Here are the details:
Setup:
Microcontroller: PIC16F877A
Sensor: DHT22
Connections:
VCC to 5V
GND to Ground
Data to RA0 (10k pull-up resistor)
Code:
c
#include <xc.h>
#define _XTAL_FREQ 20000000
// Configurations
#pragma config FOSC = HS, WDTE = OFF, PWRTE = ON, BOREN = ON, LVP = OFF, CPD = OFF, WRT = OFF, CP = OFF
void init() {
    TRISA = 0x01;
    ADCON1 = 0x07;
void read_sensor() {
    // Reading logic
void main() {
    init();
    while(1) {
        read_sensor();
        __delay_ms(2000);
Issue:
Readings fluctuate significantly.
No correlation with actual conditions.
Stable power supply and secure connections.
Help Needed:
Has anyone experienced this? Any advice on resolving these fluctuations?
Moderation: link removed
Re: Inconsistent Sensor Readings with PIC16F877A and DHT22
I just had this problem too. Did you solve it?
My (completely uninformed) guess is that the serial read protocol is incorrect so that the output data isn't properly synchronised and gets misinterpreted.  A quick skim of the datasheet leaves many questions unanswered.  This will be hard to solve unless you have an oscilloscope or serial analyser to view the signals and see what's happening (although suitable kit is very cheap these days).  An alternative is to ask the supplier of your DHT22 for support.
This forum does not seem to be the right place for this question, even in "off topic"!  Surely there are maker forums more suitable.
