Hi- I'm new and not sure where to post this. I am trying to get to know foobar2000 as I have heard it is an excellent proram. I've been following a guide to help me set it up. I got to the part where it says to go ahead and convert the FLAC. I right-click and go to convert. The quide I'm using says the first time I do this it shold ask where LAME.exe is. However, it does not, so I can't tell it where it is. It therefore converts the FLAC into... a FLAC. I have looked all over for some place to add LAME.exe and have been unsuccessful. Any help would be greatl appreciated.
'Ol Fleshy
I would add the lame.exe file to the main program folder:
C:\Program Files (x86)\foobar2000 - for the 64 bit version of Windows
or...
C:\Program Files\foobar2000 -- for 32 bit
or...
The other way.
By the way, foobar2000 doesn't come in 64bit, the installation is always 32bit in "\Program Files (x86)\"
The 64 bit version of Windows creates a second “Program Files” folder for 32bit programs. Anything that goes into "\Program Files (x86)\" is a 32bit application. Foobar2000 is a 32bit program. Hence, its program files are located in that folder. There is no need for this second “Program Files” folder in the 32bit version of Windows. But I had no way of knowing which version the OP was using, so I listed both.
Of course, neither of this is relevant to the topic.
Understood your reply now, sorry working in IT and used to most clients I read your comment in a completely different way that you meant it.
Since you are using foobar2000, its General subforum would have been a logical place. Moved accordingly.
