Topic: Titleformat - Error checking (Read 865 times) previous topic - next topic
I had not changed column scripts for quite a while; because of that, when I needed to use the length function I misspelled it as $length() (instead of the correct $len()).
Well, although I noted that the script wasn't working properly, it took me a long time to realize that I was using a non-existent function.
It would be nice if such errors could be flagged to alert users.
Re: Titleformat - Error checking
That would indeed be a benefit. I remember me and @davideleo going over an $if statement in a thread which included $sum that didn't work at all. Only a good hour later it was noticed that $sum doesn't exist, but $add does. Simple stupid mistakes could be avoided with some flagging.
There's that titleformatting sandbox plugin for foobar and highlight scripts for notepad++ and maybe couple other editors. You might want to look into those.
Thanks, was not aware of foo_tfsanbox.
