Topic: Foobar2000 Mobile 1.4.1 Playlist problem (Read 657 times) previous topic - next topic
Dear
Good days.
For now, I have just noticed one problem.
For mobile version, after updating to the new version, 1.4.1.
My playlist didn't work anymore.
I should said it more clearly.
Because it is a little bit difficult to manage the playlist on android rather than on PC, I usually make a playlist file, file type ".m3u8", and put it in a folder named "Playlist". Then use the fb2K on mobile to import it as "playlist folder".
And I put my music in different folder.
So there will be two folders, one is for playlist and the other one is for my musics.
The file path I wrote in playlist file will be as following,
For example:
"../Music/AAA.mp3"
It will work before.
However, after updating to new version, it can not work if I selected that folder as "Playlist folder".
But, if I directly choose the playlist file from "External Storage", that playlist file can work.
As following:
The error description is as following, 6230-6431 should be my SD card's number.
"playback error: Document 6230-6431: playlist/../Music/AAA.mp3 is not a descendant of 6230-6431: playlist on:[android] 6231-6431: playlist/../Music/AAA.mp3""
Will this problem be fixed in future? or there are some way to solve it?
Re: Foobar2000 Mobile 1.4.1 Playlist problem
I don't think your description is a software issue.
The operation you almost imported in between
Because the software recognizes M3U8 as a media file rather than a playlist
After you open the M3U8 file, click on the tool in the upper right corner, and then open the file association at the bottom
Importing into a newly created playlist can solve the problem.
Good luck to you.
你的描述我认为这个不是软件的问题。
你中间差一步导入的操作
因为软件把M3U8识别成一个媒体文件而不是播放列表
你打开M3U8文件之后,点右上角工具,然后打开最下面的文件关联
导入到一个新建的播放列表就可以解决问题了。
祝你好运。
Thank you for your reply.
However, it didn't work on me.
Please press the command" play location" and choose "add to playlist" or "create playlist".
It showed " could not process incoming tracks: Object not found."
Thank you.
look my topic
open .M3U8 file,add playlist by this step
"TOOLS - CONTEXT MENU - PROCEED"
process to new playlist .
