Topic: Kameleon by Br3tt (Read 321513 times) previous topic - next topic
Kameleon by Br3tt
Reply #275
After an ATI driver update, I can no longer import fcl's. Is chronflow the problem? For the hell of it, I found a config on Deviant Art that doesn't use chronflow and it imported fine. Otherwise, an import with a chronflow requirement crashes foobar. I'm assuming chronflow is the issue.
So my question is: Is there any way to use your config without a chronflow import requirement?
Kameleon by Br3tt
Reply #276
just for you : http://br3tt.free.fr/html/K/index.htm
check line #3
Kameleon by Br3tt
Reply #277
Uhm is it intentional that the artist isn't displayed in the background by default? Now I have to click the alien cat every time I want the artists to show.
Otherwise it's a fine update
Kameleon by Br3tt
Reply #278
check line #3
Sweet! Thanks!
Edit: That did it. I'm back in business....thanks again.
Kameleon by Br3tt
Reply #279
up 5 posts!
Kameleon by Br3tt
Reply #283
Last post on page syndrome.
Btw you will have this problem all the time since the changes/additions in the docs aren't highlighted. And nobody will bother reading the entire thing to find the few changes.
Kameleon by Br3tt
Reply #284
I just did a brand new foobar2000 install and got the full kameleon pack and imported the fcl and then noticed when I hover over a track that the popup is white box only. Am I missing some setting setup?
Kameleon by Br3tt
Reply #285
ELP Settings/misc/enable colour key/transparent
Kameleon by Br3tt
Reply #286
ok I did that and now when I hover over a track nothing shows....is that the idea? I thought the popup was supposed to show track info and stuff?
Kameleon by Br3tt
Reply #287
It shows comments
No comment = no pop-up
Add a comment and try it then
Kameleon by Br3tt
Reply #289
It shows comments
no comment does mean a pop-up
http://www.hydrogenaudio.org/forums/index....st&p=617198
Kameleon by Br3tt
Reply #290
The new versio is just awesome!!!!!!!!!!!!!!!!
thanks alot Br3tt!
Kameleon by Br3tt
Reply #292
not a doc addition Andu, all was discribed since the 1st release, but as i see, you'ven't read it the first time too
B/ Panel Stack Splitter settings (panels that can be shown/hidden on startup)
Default layout display the left panel with 3 mini panels (ART, LYR and SPE) + right panel (collapsed). For your convenience, you can choose which panels to show/hide on startup if these don't match your tastes
1. for the mini-panels in the Left Panel, Right click on the Left Panel header (ART PHO LYR ... SPE) and enter Splitter settings,
then for each panel beggining by "->", you can check or not the 'hide panel on startup' option (restart needed of course coz of startup options )
btw, when i make additions in the doc, i indicate it in the change log ! The next time i'll use highlight effects for you ...
1.1a :
- album list panel and playlist switcher panel moved to the left panel as mini-panels
- added QuickSearch toolbar always visible at the bottom of the left panel + Quicksearch buttons to look for same ... artist/album/title or genre
- added 2 buttons + and - to collapse/expand groups in the active playlist
- bug fix in Track info panel about db info doubled + some alignement fixes
- added a new button in the playlist header area to hide/show the top panel (Path + Google buttons + Last.FM radio button)
- added a grid dot background for the now playing panel (under scrolling texts)
- added Popups in ELPlaylist on Track mouseover if %comment% exists (display the comment in the popup)
- added Popups in the right Graphical Browsers (artist + album for Cover case mode, artist name for photo mode)
- dropdown menu entries are now transparent
- documentation updated below (popup transparency in ELP, statistics &rating : where to store them? ... ), check chapter D
- tweaks
NO COMMENT !
Edit: typo
Kameleon by Br3tt
Reply #293
1.1a :
- tweaks
Kameleon by Br3tt
Reply #294
SEX SEX SEX SEX SEX SEX SEX SEX
INCREDIBLE job, Br3tt!!! I am positively stoked .
Will begin testing now! So far so good!
Kameleon by Br3tt
Reply #295
1.1a :
- tweaks
NO COMMENT !
Edit: typo
Erm thx for not being patronizing
Have you actually checked chapter D? Because after reading the changelog (before downloading the new version) I did. The force wallpaper thing is not mentioned in that chapter.
Just for the heck of it I tried to be fair and ran a string search on both the terms 'force' and 'wallpaper' in your docs too. Neither leads to a passage in the docs that could solve that issue.
But yea the problem is obviously with me
Edit: Oh wait I'm supposed to magically know that there is a new entry in the Panel Splitter Settings or that you've changed a value in there.
Kameleon by Br3tt
Reply #296
as said, there  is NO new entry !! all was explain in the doc since the beginning, but i see that you don't want to understand... that's a shame ...
Kameleon by Br3tt
Reply #297
Oh I understand you perfectly well but you don't seem to understand me.
Once again.
1) The doc does not mention that there is an option to force a wallpaper.
2) The changelog does not mention that such an option was added or that a preexisting option was changed.
So unless you expect every user to know each option by heart and actually review every single panel on every update there is no way in hell anybody can know this. Especially not somebody that doesn't have the time to read every single post in this thread.
But like I said it's obvious that the fault lies with me.
Kameleon by Br3tt
Reply #298
well, i guess string search doesn't search in the screenshots  -> Force Wallpaper - tick/untick hide panel on startup? is this helpful?
Br3tt is working his ass off with pleasing people around and some here are acting like "whining little bitches" (damn, i've always wanted to say that )
99% problems here is already solved in docs, you just have to read and look carefully
