Phone: Samsung GTS 5830 / Android 2.3.6 / player = PowerAmp
Wavpack Lossless :
wv fast - 12%
wv - 15%
wv high - 20%
wv vhigh- 26%
Wavpack Lossy:
wv 320 - 19%
wv 320 vhigh - 29%
Lossless Others:
flac - 10%
ape fast - 28%
ape - 40%
ape high - 55%
ape extra->70% (phone slow + hot !) Audio played fine though.
Lossy others:
mp3 320 - 23%
ogg 320 - 19%
aac SBR/PS - 24%
aac LC 320 - 14%
mpc 320 - 13%
This is only one test but I hope it shatters some myths. IMO Wavpack normal / fast mode can be competitive with flac. WV -h is also 'fast' and -hh is heavier but only a bit more compared to mp3 / ogg. The -h -hh are faster encodes / better compression than flac -8 and competitive with APE -c1000
Monkeys Audio which has been criticized for slow cpu decoding. The -c1000 fast mode is a surprise. On par with WV -hh and maybe a bit faster to encode and compress slightly worse. The -c2000 normal mode was heavier @ 40% but the phone and playback were fine. This is still acceptable for those needing extra compression , the encoding is fast, decoding a bit worst than WV -hh. -C3000 high mode also played ok but cpu was %55 . Maybe this is the absolute maximum for compression freaks. Its still encodes fast but IMO -c2000 is more sensible while -c1000 for raw speed while still better than flac -8 for compression and much faster. The -c4000 extra high may produce a disaster. Phone slow and HOT, slow seeking, cpu >70%. Not suitable IMO only for PC use or for better H/W. Its also encodes much slower to wv -hh and the other modes but better compression.
CPU % won't be very accurate because most of those formats aren't slow enough to use more than a few percent CPU. Here are some older tests on a similar CPU done by counting decoder cycles exactly:
http://www.rockbox.org/wiki/Main/CodecPerf...5EJS_41_Android (http://www.rockbox.org/wiki/Main/CodecPerformanceComparison#Qualcomm_MSM7227_40ARM1136_45EJS_41_Android)
Interesting results.
However ARM9 and ARM11 are considered as legacy. The most of mobile device today have Cortex A chip which have NEON instrustion set. Even Cortex A9 is considered today as "old" .
All low-budget lines with ARM11 were replaced by Cortex A5 a few years ago.
Great post shadowking.
I've been listening to my lossy WV files (encoding params as per my sig, no correction files on mobile) on my budget Motorola Moto G 4G (1st Generation, Qualcomm MSM8926 Snapdragon 400, Lollipop 5.1.1) via Rocket Player Premium for more'n 2 years now and still haven't been able to notice any additional battery drain compared to MP3 VBR or AAC TVBR playback.
