Topic: Need to erase Field tag memory (Read 1285 times) previous topic - next topic
Hello,
i created my own tag to classify my music,
i rate my tracks by 1 to 5 with a Field tag named "NOTE"
however sometimes i want to tag it speedly and i text "NOT2" or "NOT3" caus' i didn't switch from Filed name to Field value,
instead i erase all this false "Field name" they still appear in selection of "Field name" when i tag a track,
this is a problem cause i created tag with different thirst caracter to text them shortly, for example i had only two tag that begins by letter "N"
here a screenshot of some of tag field i want to erase from database :
Re: Need to erase Field tag memory
You should probably add frequently used custom fields to standard in order to access them quicker directly from the properties dialog and make their appearance nicer.
Preferences -> Advanced -> Display -> Properties -> Standard fields
Oh great!
This is so usefull options!
Thank you so much!!
