Topic: Playback Statistics component: v3.x foo_playcount (Read 222993 times) previous topic - next topic
Re: Playback Statistics component: v3.x foo_playcount
Reply #475
Hello Peter Pawlowski, I have long wanted to thank You for such a grand/amazing program as/how Foobar2000. Thank(s) You. By this plugin to me questions. How can lift the rating in this plugin to 9? And read please reply #472.
Reply #476
I don't know if Peter understands reply #472. It certainly doesn't make sense to me. But if it's related to your attempts to abuse shell links (*.lnk file) the issue will be solved by using proper method to duplicate tracks.
I don't see the rating scale changing. It would break compability and 0-5 scale is pretty universal. Though modern online world seems to have moved to just "thumbs up" or "thumbs down" rating.
Reply #477
But me need 0-9 or 0-10 scale. And me more convenient to watch rating by stars. I also want files to be duplicated according by rating (or scale).
Reply #478
%added% show nothing(N/A). I have this components from Feb 2024 and added many tracks. Tried with new portable v2.1.5, tried v1.6.18... same result. Maybe I miss something but cant find what. Tried with MP4, MP3, FLAC files.
Here is picture from new foobar2000(v2.1.5) portable installation and Column UI. Maybe Why "Show recently played" and "Show recently added" are in gray?  ::) (example to show you only %added% show nothing, while %play_count% works fine)
Reply #479
For %added% to work, you must configure the Media Library (Preferences>Media Library) to watch your music folder(s). I can tell you've not set it up because of those grayed out items on your Library menu.
Reply #480
The clickable star Rating column returns the %rating_stars_fixed% format once a rating has been assigned. Is it possible to return the %rating_stars% format rather than %rating_stars_fixed%?
