Topic: can you help me to fix cue /flac playlist? (Read 1013 times) previous topic - next topic
hi
I have ripped some cds with eac -> flac  for example
Porcupine Tree - Up The Downstair CD1.accurip
Porcupine Tree - Up The Downstair CD1.cue
Porcupine Tree - Up The Downstair CD1.log
Porcupine Tree - Up The Downstair CD1.flac
in the cue there is
PERFORMER "Porcupine Tree"
TITLE "Up The Downstair CD1"
FILE "Porcupine Tree - Up The Downstair CD1.flac" WAVE
in the mp3tag there is ..screenhsot , can't upload pictures
screenshot
foobar2000 settings screenshot
screenshots number 2
playlist same album
screenshot numer 3
since musicbee , aimp can read all of them without any problems ,only foobar2000 does it show
is there a fix ? is there an option in foobar ? or have I to re-tag the music file with the same for example title Up The Downstair CD1?
may i know what should i do ?
thanks
Re: can you help me to fix cue /flac playlist?
francesco you use this phrase a lot; to a native English speaker it sounds like you feel the answer is being "withheld" from you so you have to beg someone to "allow" you to know the answer.  It's perfectly fine to just ask "can anyone tell me how to do/fix this?", or "how do I make this (not) happen?"--that's not "impolite" in the least.  You've got the same right as anyone else to ask for help.
For the record I don't use CUE sheets so don't have the background to answer your question.
Install component foo_cuefixer - https://github.com/RevenantX/foo_cuefixer/releases
Hi Bogozo
it seems to fix everything , can i know if this plugin/component change the cue sheet file or the flac tags?
in the foo_cuefixer there is no options outside
Remove "*.CUE" from preferencess->shell integration->exclude file types
- Removes duplicate song entries that appear when adding adirectory containing a .cue file that links to timestamps in a base .flac/.wav/.ape file.
- Removes such duplicates also when adding tracks from media library.
- Removes broken .cue files that point to missing files (.flac/.wav/.ape etc).
what does it mean removes broken cue ? does it delete them ?
thanks Bogozo
It doesn't touch any cue or audio files at all. It just corrects their appearance in playlist and library.
