Topic: Using command line tool on network drive from run service (Read 1008 times) previous topic - next topic
I set command for pcutmp3 in run service to split mp3 from cuesheet:
cmd /c cd "$directory_path(%path%)" & java -jar c:\Programs\foobar2000\scripts\pcutmp3.jar --cue "$replace(%path%,.mp3,.cue)" "%path%"
This works fine for local drive but not for local network (i.e. //raspberrypi/...)
Does anyone know how to set the command so that it would work on local network?
Currently it just writes splitted files in a folder where foobar is, as cmd does not accept unc paths, and I would prefer not to complicate too much as it is.
Re: Using command line tool on network drive from run service
Good idea, thanks
