Topic: CUERipper failing due to "..." at the end of album title (Read 2054 times) previous topic - next topic
Using version 2.1.8HR1.
I have an album with title ending with "...".
At some point, CUERipper fails saying that it doesn't find "a part of the path".
I removed "..." from the title, it's now working.
Re: CUERipper failing due to "..." at the end of album title
I can confirm this Issue. On CueTools 2.17 I've never  had this Problem.
Instead of deleting the three dots from the title, you could use the Ellipsis [1] Unicode character "…" instead of the three dots. In this case, the "…" will also show up in the path.
[1] https://en.wikipedia.org/wiki/Ellipsis
CueTools 2.17  was removing the three dots at the end of the path, without user intervention. Somthing has changed, so CueTools 2.18 can't handle this.
In the meantime, a fix has been prepared for album titles containing three dots at the end.
Feel free to test the updated CUETools build found here:
https://github.com/gchudov/cuetools.net/pull/99
Bug is still there in version 2.2.1.
