I happen to have an album in flac format ( flac image + cue) with their cue files. However i want them in flac with their respective tracks and cue files.
If i copy the flac files with cues to a CDR (using EAC) and then rip that same CD to flac (with correct offset) would it sacrifice any loss in quality?
To Simplfy:
I happen to have a CD of Cream .. Album name is Fresh Cream ; Polydor ; 827-576-2
A few years ago i ripped that CD to FLAC format using EAC with correct drive offset and drive offset (set it up using blowfish' guide) . However it was one single image with a Cue and log file.. It was accurately ripped
Now a few days ago , that Cd got destroyed and i want to have a physical CD copy .. I burnt it on a CDR with the correct drive offset. No errors and it was accurately ripped
i wanted to own a copy of the CD in flac format with separate tracks and cue , log (not in single image)
Now I don't own the original cd anymore and i burnt a CD copy from my single flac image + cue a few days back
My question is if i rip the ripped the copied CDR would i have any loss in quality? even though if it has no errors or accurately ripped
Long Story short .. Ripping from a CD-R (with correct offset , accurately ripped with no errors) would it cause any quality loss?
hope my question was not too confusing~
No loss of quality
you don't need to burn to cd-r to split tracks, google cuetools
Since the FLAC Image is already on his hard drive sitting next a matching CUE file...
can he not just drag the CUE sheet into a foobar2000 playlist window and highlight all and then right click "convert" (to separate FLAC tracks).
Job Done. No need to install "Microsoft .NET Framework version XXXX" just to use a tool !
(I don't have anything against CUETools, but I run a very lean Operating System with no .NET or JAVA etc, and I have a preference for native programs).
Yes, he can, assuming he wants to split with gaps appended and discard HTOA(?).
One can use EAC as well, provided the flac is decompressed to wave first.
