Topic: NEW ESLyric v0.5 - an alternative lyric show component (Read 70906 times) previous topic - next topic
Re: NEW ESLyric v0.5 - an alternative lyric show component
Reply #200
The version that worked was v1.0.0.1017 Alpha.
SHURE SRH1840, SENNHEISER HD660S2, SENNHEISER HD620S, SENNHEISER HD 490 Pro Plus, beyerdynamic DT 1990 PRO, HiFiMAN Edition XS, Bowers & Wilkins P7, FiiO FT5, 水月雨 (MOONDROP) 空鳴 - VOID, Nakamichi Elite FIVE ANC, SONY WH1000XM5 (made a Upgrade/Balanced Cable by myself)
Reply #201
Ken the last release version at the Github site before 1019 is 1016 Alpha, not 1017.  He skips versions sometimes.  He responds much faster if you post the problem at Github, I've done that several times.
Reply #202
here
https://github.com/ESLyric/release/releases/tag/1.0.0.1007
https://hydrogenaud.io/index.php/topic,122571.msg1047120.html#msg1047120
Reply #203
@sveakul
Sorry, the version is wrong.
ESLyric 1.0.0.1007 (Alpha) (foo_uie_eslyric) 2024-06-30
The latest version at this time
v1.0.0.1019 Alpha:
Reply #199 https://hydrogenaud.io/index.php/topic,122571.msg1049328.html#msg1049328
Are you not having this problem?
Reply #204
Try *1020 just posted today, fixing a text alignment issue I had with the display.banner.text, it may fix your issue too.  I use only panel version not desktop version.
I posted the problem on Github yesterday and he fixed it today, not bad!!  You should use Github for issues with ESLyric, and also with foo_openlyrics, the developers have requested this for best response.
Reply #205
@sveakul
But the problem is not solved: images are small and text is overlapping.
Display resolution:
X   3840 x 2160
〇 1920 x 1080
It was a display resolution issue.
Yes, I understand.
Many Thanks.
Reply #206
As this incredible lyrics plugin goes to 1.0.0.1021 alpha, I'd just like to remind fans of radio streams that versions of the LRCLIB and Metallum searcher plugins specifically modified to work with radio streams are available outside of the "stock" versions.
The LRCLIB searcher was modified by TT to not require an album name be sent--radio metadata almost never includes this--and modifications elsewhere to enable stream use.  These were done in a couple of stages in past Foobar posts.  Yes, still works with files as well.  I've attached it here, renamed so you can use it without overwriting the "as delivered" version.  This searcher by far gets the most hits with my usage than any other.
The Metallum searcher, also by TT, is delivered by ESLyric in a version requiring an album name to work, and so unusable on streams.  I made my own minor mod to it to allow it to need artist/track title only, and like the above modified the name so you can use it alone or together with the stock version.
These are both attached below.  Unzip and add to your ESLyrics sources via the Get More/Import Script dialog.  Just dropping them into your ../profile/eslyric_data/scripts/searcher folder is probably fine too.
Reply #207
Nevermind, I'm blind and dumb. Click on the three dots. I'll leave this up in case someone else is also blind and dumb.
How do I save lyrics to the same folder as the song? I can't remember. I had it working at one point but then I decided to save lyrics to the tag for a bit, but then I changed my mind. %directory%?
Reply #208
What Habanero is talking about
Reply #209
① Same file names are displayed in Local Files in Lyric search
② [language:~] is saved in lyrics
③ Commands are changed (since 1.0.0.1019 Alpha)
    View/ESLyric//Adjust offset
    View/ESLyric//Open containing folder
Reply #210
I downloaded the latest 1.0.0.1022 Alpha and it has this annoying fade effect for the artwork. Whenever a new artwork loads it fades in. Some people might like this but I don't. How do I turn this off?
EDIT...
This is it... "Optimize the panel display effect when switching songs".
I can't stand it. It's like something you'd see in a photo viewer. I'll have to use an older version until it can be turned off.
Reply #211
①You choose different online lyrics and then save them temporarily.
② [Languag: ~] should be the content of the lyrics.
③Commands are lowered to the panel, and you play a song before viewing the commands。
View/ESLyric/Panel/...
Reply #212
① In ver 0.5.4.1028, displayed only one even temporarily.
② In ver 0.5.4.1028,[Languag: ~] is omitted.
③ Before ver 1.0.0.1016 Alpha I have assigned commands to buttons,
   but after ver 1.0.0.1019 the following two commands give me errors
Reply #213
1. I remember that there would always be a few temporary displays, but it didn't have any effect, it was just temporary.
2. What lyrics source, what song, I'll try
3. The command has changed, and you have modified it according to the new one.
Reply #214
2.Every lyrics same.
  (kugou.js) [id:~], [language:~] is saved.
  (ex. Bon Jovi - Livin' On A Prayer)
  (and Japanese lyrics [kana:~] is saved )
Reply #215
It is not displayed in the lyrics panel and is not processed
Reply #216
I often modify lyrics, so I cut [language:~],[kana:~] because they are very difficult to see.
The previous version was cut, which is good for me.
Reply #217
EDIT...
A new version is out today. Thanks for adding the option to change the transition time. 0 will disable it.
Reply #218
Hello.
I do not know why my UI do not look like ur screenshot.
My plugin version is ESLyric v1.0.0.1023 (Alpha)
Even if I remove plugin and reinstall. It still show all my old config.
Reply #219
Hello.
The three dots [...] icon in the upper right corner of the picture has import and export functions. You can install a fb+esl portable version, export the default configuration from it, and then import it.
Reply #220
Hello.
If you remove the plugin from the Components list, to completely wipe the original config/data also be sure that the folder "eslyric-data" is deleted from your Profile folder, and the file "foo_uie_eslyric.dll.cfg" is deleted from your Profile/Configuration folder.
Reply #221
The layout function of the new version of ESLyric has been updated, waiting for the author to update the document
Reply #222
O wow, I hope it supports transparency now like it did in 0.5.4.1028, which I am still using because of that ...
Reply #223
@always.beta
ESLyric 1.0.0.1028 (Alpha)
Where is "default.xml"? I forgot.
\foobar2000\profile\eslyric-data\layout\default.xml
Oh, are we waiting? Sorry.
Reply #224
@always.beta
Also looking forward too
