Dear all,
I have some big ape-files I like to transcode. I have found some tutorials how to do this with monkeyaudio-program, but it only decompresses to one large wav-file, ignoring my cue-sheets. When I convert the wav to ALAC via itunes it also ignores the cue-sheet.
In which step is my dear cue-sheet being used so I end up with 20 songs from a CD?
Peter
Have a look at this tool:
http://www.hydrogenaudio.org/forums/index....showtopic=66233 (http://www.hydrogenaudio.org/forums/index.php?showtopic=66233)
You would drag and drop the cue sheet into the application and select your desired output format and codec then start the conversion and hopefully get what you want.
