Hi, I downloaded foobar 2000 v1.1.15 and it works great to play files.
I also downloaded the Audio CD Writer v 3.03... And it shows up under Preferences: Components...
But I don't see any way to access that feature...
Nor any way button that says "convert". to convert file types....
Can someone direct me to a beginner guide? Or tell me what I am doing wrong?
I have windows 7 on my computer, if that is important.
Thanks or your help
In foobar2000, you frequently need to select multiple items (http://windows.microsoft.com/is-IS/windows7/Select-multiple-files-or-folders) and use the context menu (i.e. right-click).
Thanks for your help...
When I highlight items in playlist, and right click, I get a popup with options like: Replace UI Element, Copy UI Element; Cut UI Element, Columns and Groups.
Nothing about the other features? What am I doing wrong?
you have enabled layout editing mode
view > layout > enable layout editing mode
Thanks! That seems to have worked! Could have sworn I'd tried that that a few times... But Success! Thank you
