Lossless codecs in frequency domain?
Reply #11 – 2010-11-20 10:11:30
That being said, I believe it is only a matter of time before more efficient and novel algorithms replace the primitive linear glottal model, that leads to LPC, which was meant for speech coding in the first place. Actually, LPC is not that primitive after all, as I found out during my work. But you're right about the novel algorithms: an integer MDCT is used in HD-AAC (which by the way can also operate in pure-lossless mode).Or for a 4 minute track, it would take 3.4 milliseconds! Of course, if you want to do the MDCT, you'd have to pre/post rotate your data, which might add another millisecond to that runtime! Hope you can spare it while you wait 5 minutes an album for FLAC's linear prediction and entropy coding. A little more polite and careful, please, saratoga! An (M)DCT of a waveform alone doesn't give you any compression, it's just a transform. So for a fair comparison, you would have to either compare only (M)DCT vs. LPC analysis and filtering, or compare (M)DCT + entropy coding vs. LPC + entropy coding. From my work experience in that field I can tell you that most of the time, entropy coding is more expensive that LPC or T/F transform, especially in the encoder. That taken into account, LPC- and transform-based codecs are probably quite close to each other speed-wise (with LPC-based codecs probably being a little faster on decoder side since usually, no analysis operation is needed there). Also, a common flaw I see here on HA audio is that people tend to think only of PC-based applications of audio codecs. On portable devices with relatively weak processors, battery life is critical, and the industry is looking for codecs with minimum decoder complexity. Now take a guess why e.g. APE hasn't reached that market. Nobody likes it when your portable's battery is empty after playing two lossless songs (if it can play them at all). (No, in the real world, with the rise of flash storage, disk speed and memory latency soon won't matter more then raw fft performance.)Can you rephrase this more coherently? I'm not sure if you're just being scatterbrained or really have no idea what you're talking about. JapanAudio's comment made perfect sense to me. Do you know what (s)he is talking about? Chris
