Topic: MAREO 4 Released! (Read 124375 times) previous topic - next topic
MAREO 4 Released!
Reply #50
i would take a look at cuesheet thing ... i don't want REACT to steal my users  ... give me a couple of days ... meanwhile, i'm accepting eac+cue+MAREO use examples (besides this one).
MAREO 4 Released!
Reply #51
For what is worth, I too use the same archival method as freak393: a single wavpack with embedded cuesheet for archival and an mp3 for each track for everyday playback.
Actually my process right now is:
1) Rip image (.wav) + cue with EAC, setting at least "CD Title", "CD Artist", "Year" and a "Title" for each track.
2) Load the cuesheet into foobar2k and apply album replaygain (values are written in the cuesheet)
3) Encode "the cuesheet" (that is the CD image seen as several tracks) to mp3
4) Apply album replaygain to the mp3 tracks
5) Move the mp3s to a different directory (/My Music/Mp3/Album Artist/[Year] - Album Title/)
6) Encode the .wav image (seen as a single track) to .wv
7) With tag.exe add to the .wv ALBUM, ARTIST and DATE tags and and embed the cuesheet
8) Change suffix to the cuesheet from .cue to .cue.txt
It is not yet clear to me if MAREO can achieve a similar result. If it can... I'm sold!
Regards.
Sergio
Sergio
M-Audio Delta AP + Revox B150 + (JBL 4301B | Sennheiser Amperior | Sennheiser HD598)
MAREO 4 Released!
Reply #52
kwanbis - if you would really do that - GREAT !!!
If I can - with the little knwoledge I gained so far - be of any help, let me know!
Regards, Phil
MAREO 4 Released!
Reply #53
Will mareo do a command line verify check on WavPack files afterward, since there is not an encoding option sto do it while encoding (like FLAC's -V option)?
I am gonna try mareo to do this and just need to get my ini file just right:
1. rip to WAV (duh)
2. encode to WavPack lossless files (no cue/image)
3. add APEv2
4. apply ReplayGain (wvgain.exe) values
5. verify the .wv files
6. additional lossy encodes from the WAVs...
Will the .wv files just need another pass and can I automate this with mareo?
MAREO 4 Released!
Reply #54
first, you should download latest MAREO version. Once you have done that, test by ripping the problem track to wav, and then encode it with oggenc. If it fails, is not MAREO.
Thanks for the tip. I tried your suggestion and I got the same result running oggenc2 from the commandline with the same arguments. So I fiddled a bit with the arguments and I found that the responsible for the crash is the "TOOL" line, removing the part ", VorbisGain 1.01" fixes the crash! And since I deleted VorbisGain from the computer (it destroys Vorbis files' padding when you apply the Replaygain correction), that part of the line is useless. Unfortunately, fixing the encoding of this song breaks the encoding of others like "Highway Star", which only encodes if you remove most of the arguments, leaving only the "artist" and the "album" arguments. Should I send a PM to John33 notifying him of this bug?
About the single file + cuesheet method in MAREO, I think it needs some internal changes to do the thing. I brainstormed some ideas at home using ACDIR, but nothing good came out of it... By the way, do cuesheets accept more information fields than the the format standard? I was thinking about using the cuesheet method, but if you can't write custom information about each track in the cuesheet, it's useless to me.
MAREO 4 Released!
Reply #55
1. rip to WAV (duh)
3. add APEv2
Here is my attempted ini:
; WavPack: excelent lossless encoder
EXECUTEIF = TRUE
FINALPATH = [PERSONAL]\Music\[ARTIST] - [ALBUM]\
FINALNAME = [TRACKPADDED] - [TITLE]
EXTENSION = wv
ENCODEREXE = wavpack.exe
PARAMETERS = -m "[SOURCE]" "[DESTTMP]"
RENAME = TRUE
; WavPack with APEv2 TAGS (requires wapet.exe)
; EXECUTEIF = TRUE
; FINALPATH = [PERSONAL]\Music\[ARTIST] - [ALBUM]\
; FINALNAME = [TRACKPADDED] - [TITLE]
; EXTENSION = wv
; ENCODEREXE = wapet.exe
; PARAMETERS = "[DESTTMP]" -t "Artist=[ARTIST]" -t "Album=[ALBUM]" -t "Title=[TITLE]" -t "Track=[TRACK] -" -t "Year=[YEAR]"
; RENAME = FALSE
; WvGain
EXECUTEIF = TRUE
FINALPATH = NONE
FINALNAME = NONE
EXTENSION = NONE
ENCODEREXE = wvgain.exe
PARAMETERS = -a "[FINALPATH]*.wv"
RENAME = FALSE
; WavPack Verify
EXECUTEIF = TRUE
FINALPATH = NONE
FINALNAME = NONE
EXTENSION = NONE
ENCODEREXE = wvunpack.exe
PARAMETERS = -v "[FINALPATH]*.wv"
RENAME = FALSE
I tweak it here and there but am still not getting anything beyond a completed .wv file.
What am I doing wrong?
MAREO 4 Released!
Reply #56
Hey there kwanbis...
Don't mean to push you - but did you have a look at the "create single wavpack with cue" issue yet? Could you give an update on the situation?
It's greatly appreaciated!!!
MAREO 4 Released!
Reply #57
sorry, i'm actually in "world cup mode" ... so little time :|
MAREO 4 Released!
Reply #58
I'd like to know who can use MAREO from foobar 0.9.2
I see that kwanbis has had luck.
I have not had any luck on 0.9.x on my system or on another.
If you've has success, how about posting your mareo.ini and all settings from foobar.
Thanks! This is the only thing keeping me from moving to foobar 0.9.2
I won't be without MAREO...
MAREO 4 Released!
Reply #59
Alright - then you just saw us (Germany) crush Ecuador 3:0
Where are U from? [EDIT: Ah well "http://webearce.com.ar" gives it away... - SO, we might "meet" on OUR way to world champion    ]
Got to go: England v.s. Sweden just started...
Enjoy - Phil
MAREO 4 Released!
Reply #60
Little problem w/ Mareo trying to write a filename w/ an illegal character...
* MAREO - Multiple Applications Runner for EAC and Others *
* Copyright 2003-2006 by Kwanbis -- Under the GPL License *
* Version 4.0.3 - Home Page at http://www.webearce.com.ar *
* Developed with Borland Delphi http://borland.com/delphi *
*** Received Command Line ***
"C:\multi_frontend\mareo\mareo\mareo.exe" mareo.ini "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav" "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.fake" "Audio Adrenaline" "Worldwide" "Worldwide: One" "01" 2003 "Christian Rock" "12"
*** Parsed Parameters ***
INIFILE       (%1) = mareo.ini
[SOURCE]      (%2) = C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav
[DESTTMP]     (%3) = C:\music\Audio Adrenaline\Worldwide\0tmp660-!.fake
[ARTIST]      (%4) = Audio Adrenaline
[ALBUM]       (%5) = Worldwide
[TITLE]       (%6) = Worldwide: One
[TRACK]       (%7) = 1
[TRACKPADDED]      = 01
[YEAR]        (%8) = 2003
[GENRE]       (%9) = Christian Rock
[1]          (%10) = 12
*** INI Parameters ***
Padding Zeros        = 2
LogToScreen          = TRUE
LogToFile            = TRUE
DeleteWavFile        = TRUE
*** mareoLAST.INI ***
[LASTTRACK]          =
*** PROCESSING ENCODER ORDER # 1 ***
EXECUTE IF         = TRUE
NEW EXTENSION      = ogg
TEMPORAL FULL NAME = C:\music\Audio Adrenaline\Worldwide\0tmp660-!.ogg
TEMPORAL PATH ONLY = C:\music\Audio Adrenaline\Worldwide
TEMPORAL NAME ONLY = 0tmp660-!
RENAME FINAL FILE  = TRUE
FINAL FULL NAME    = C:\music\Audio Adrenaline\Worldwide\01. Worldwide: One.ogg
FINAL PATH ONLY    = C:\music\Audio Adrenaline\Worldwide
FINAL NAME ONLY    = 01. Worldwide: One
EXECUTING: c:\multi_frontend\oggenc.exe -q4 "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav" -o "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.ogg" -a "Audio Adrenaline" -l "Worldwide" -t "Worldwide: One" -N "1" -d "2003" -G "Christian Rock" -c "TOTALTRACKS=12"
EXECUTION: SUCCESS
DIRECTORY "C:\music\Audio Adrenaline\Worldwide" allready exists.
RENAMING: C:\music\Audio Adrenaline\Worldwide\0tmp660-!.ogg =] C:\music\Audio Adrenaline\Worldwide\01. Worldwide: One.ogg ... -ERROR-
*** PROCESSING ENCODER ORDER # 2 ***
EXECUTE IF         = TRUE
NEW EXTENSION      = NONE
TEMPORAL FULL NAME = C:\music\Audio Adrenaline\Worldwide\0tmp660-!.NONE
RENAME FINAL FILE  = FALSE
FINAL FULL NAME    = NONE\NONE.NONE
FINAL PATH ONLY    = NONE
FINAL NAME ONLY    = NONE
EXECUTING: c:\multi_frontend\wavegain.exe --radio --apply --noclip "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav"
EXECUTION: SUCCESS
RENAME IS FALSE, NO need to rename.
*** PROCESSING ENCODER ORDER # 3 ***
EXECUTE IF         = TRUE
NEW EXTENSION      = ogg
FINAL FULL NAME    = Z:\music\Audio Adrenaline.01.Worldwide: One.2003.ogg
FINAL PATH ONLY    = Z:\music
FINAL NAME ONLY    = Audio Adrenaline.01.Worldwide: One.2003
EXECUTING: c:\multi_frontend\oggenc.exe -q1 "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav" -o "C:\music\Audio Adrenaline\Worldwide\0tmp660-!.ogg" -a "Audio Adrenaline" -l "Worldwide" -t "Worldwide: One" -N "1" -d "2003" -G "Christian Rock" -c "TOTALTRACKS=12"
EXECUTION: SUCCESS
DIRECTORY "Z:\music" allready exists.
RENAMING: C:\music\Audio Adrenaline\Worldwide\0tmp660-!.ogg =] Z:\music\Audio Adrenaline.01.Worldwide: One.2003.ogg ... -ERROR-
*** Encoder Orders Ends ***
DeleteWaveFile is TRUE.
DELETING: C:\music\Audio Adrenaline\Worldwide\0tmp660-!.wav ... SUCCESS
+++ DONE +++
2 errors ocurred. Press any key to end.
MAREO 4 Released!
Reply #61
I second that. Haven't had any success with MAREO in 0.9.x either. Seems like a fb2k issue, though, cuz my MAREO setup runs and encodes at the commandline, but not within foobar.
WavPack 4.31 / LAME 3.98 alpha 3 -V9 -vbr-new
MAREO 4 Released!
Reply #62
I got MAREO 2.x working with f2k by copying the mareo.ini to the f2k directory. Haven't tried that with MAREO 4 jet.
MAREO 4 Released!
Reply #63
"If you've has success, how about posting your mareo.ini and all settings from foobar."
MAREO 4 Released!
Reply #64
Because it was MAERO 2.x (different placeholder and commands system) and f2k 0.8.3.
Only thing i did that was not like using MAREO with for example EAC was: I copied the mareo.ini to the f2K directory instead of the mareo directory. I didn't jet need to use MAREO with f2k 0.9.x but i'll post what i did as soon as i got it working!
MAREO 4 Released!
Reply #65
Hello,
Just started using Mareo and have encountered the same problem mentioned by rudefyet above when using a colon in the file/track name.  It seems EAC replaces it with a "-" but Mareo fails on the rename.
Any chance Mareo could be enhanced to recognize and substitute invalid characters? Otherwise LOVE the program.
My log:
"E:\Program Files\Exact Audio Copy\mareo\mareo.exe" mareo.ini "F:\Special Folders\Desktop\0tmp660-!.wav" "F:\Special Folders\Desktop\0tmp660-!.flac" "Emerson, Lake & Palmer" "Brain Salad Surgery" "Karn Evil 9: 1st Impression-Part 2" "06" 1973 "Rock"
[SOURCE]      (%2) = F:\Special Folders\Desktop\0tmp660-!.wav
[DESTTMP]     (%3) = F:\Special Folders\Desktop\0tmp660-!.flac
[ARTIST]      (%4) = Emerson, Lake & Palmer
[ALBUM]       (%5) = Brain Salad Surgery
[TITLE]       (%6) = Karn Evil 9: 1st Impression-Part 2
[TRACK]       (%7) = 6
[TRACKPADDED]      = 06
[YEAR]        (%8) = 1973
[GENRE]       (%9) = Rock
Padding Zeros        = 2
LogToScreen          = TRUE
LogToFile            = TRUE
[LASTTRACK]          =
EXECUTE IF         = TRUE
NEW EXTENSION      = flac
TEMPORAL FULL NAME = F:\Special Folders\Desktop\0tmp660-!.flac
TEMPORAL PATH ONLY = F:\Special Folders\Desktop
FINAL FULL NAME    = J:\flac\Emerson, Lake & Palmer\Brain Salad Surgery\06 - Karn Evil 9: 1st Impression-Part 2.flac
FINAL PATH ONLY    = J:\flac\Emerson, Lake & Palmer\Brain Salad Surgery
FINAL NAME ONLY    = 06 - Karn Evil 9: 1st Impression-Part 2
EXECUTING: E:\Program Files\FLAC\flac.exe -5 "F:\Special Folders\Desktop\0tmp660-!.wav" -o "F:\Special Folders\Desktop\0tmp660-!.flac" -T artist="Emerson, Lake & Palmer" -T album="Brain Salad Surgery" -T title="Karn Evil 9: 1st Impression-Part 2" -T tracknumber="6" -T date="1973" -T genre="Rock"
EXECUTION: SUCCESS
DIRECTORY "J:\flac\Emerson, Lake & Palmer\Brain Salad Surgery" allready exists.
RENAMING: F:\Special Folders\Desktop\0tmp660-!.flac =] J:\flac\Emerson, Lake & Palmer\Brain Salad Surgery\06 - Karn Evil 9: 1st Impression-Part 2.flac ... -ERROR-
EXECUTE IF         = TRUE
NEW EXTENSION      = mp3
TEMPORAL FULL NAME = F:\Special Folders\Desktop\0tmp660-!.mp3
FINAL FULL NAME    = G:\Emerson, Lake & Palmer\Brain Salad Surgery\06 - Karn Evil 9: 1st Impression-Part 2.mp3
FINAL PATH ONLY    = G:\Emerson, Lake & Palmer\Brain Salad Surgery
EXECUTING: E:\Program Files\Lame\lame.exe -V2 --vbr-new --id3v2-only --pad-id3v2 --ta "Emerson, Lake & Palmer" --tl "Brain Salad Surgery" --tt "Karn Evil 9: 1st Impression-Part 2" --tn "6" --ty "1973" --tg "Rock" "F:\Special Folders\Desktop\0tmp660-!.wav" "F:\Special Folders\Desktop\0tmp660-!.mp3"
EXECUTION: SUCCESS
DIRECTORY "G:\Emerson, Lake & Palmer\Brain Salad Surgery" allready exists.
RENAMING: F:\Special Folders\Desktop\0tmp660-!.mp3 =] G:\Emerson, Lake & Palmer\Brain Salad Surgery\06 - Karn Evil 9: 1st Impression-Part 2.mp3 ... -ERROR-
DELETING: F:\Special Folders\Desktop\0tmp660-!.wav ... SUCCESS
+++ DONE +++
Foobar 9.6.9, FLAC 1.2.1b, EAC 0.99 pb 5
Windows 7 Pro 64-bit
MAREO 4 Released!
Reply #66
Fixed, and uploaded.
MAREO 4 Released!
Reply #67
Howdy, I'm using EAC v0.95 beta 4, LAME 3.961, and FLAC 1.7.1 with MAREO, and all the encoding and compressing is working just dandy, but the folder/file naming is all fouled up when I run it through MAREO.  I grab the album info from freedb as normal, and encoding straight through EAC + LAME is perfect; yet for some reason MAREO catches the artist name OK, but everything else is "Unknown Album" and "Unknown Track".
In EAC Compression Options I've got it set up just like the man sez on the MAREO page.
Here's a snippet from my mareo.ini:
; MP3 LAME: best MP3 encoder: http://www.rarewares.org/mp3.html
EXECUTEIF = TRUE
FINALPATH = d:\ftp\_new\audio\music\[ARTIST]\mp3\[ALBUM]\
FINALNAME = [TRACKPADDED]. [TITLE]
EXTENSION = mp3
ENCODEREXE = c:\program files\lame\lame.exe
PARAMETERS = -V2 --vbr-new --ignore-tag-errors --ta "[ARTIST]" --tl "[ALBUM]" --tt "[TITLE]" --tn "[TRACK]" --ty "[YEAR]" --tg "[GENRE]" "[SOURCE]" "[DESTTMP]"
RENAME = TRUE
; FLAC: most supported lossless encoder: http://flac.sourceforge.net/
EXECUTEIF = TRUE
FINALPATH = d:\ftp\_new\audio\music\[ARTIST]\flac\[ALBUM]\
EXTENSION = flac
ENCODEREXE = c:\program files\FLAC\flac.exe
PARAMETERS = -5 "[SOURCE]" -o "[DESTTMP]" -T artist="[ARTIST]" -T album="[ALBUM]" -T title="[TITLE]" -T tracknumber="[TRACK]" -T date="[YEAR]" -T genre="[GENRE]"
RENAME = TRUE
And here's my log for one track attempt:
"C:\Program Files\Exact Audio Copy\mareo.exe" mareo.ini "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.wav" "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.xxx" "Tortoise" "
[SOURCE]      (%2) = D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.wav
[DESTTMP]    (%3) = D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.xxx
[ARTIST]      (%4) = Tortoise
[ALBUM]      (%5) = Unknown Album
[TITLE]      (%6) = Unknown Title
[TRACK]      (%7) = 0
[TRACKPADDED]      = 0
[YEAR]        (%8) = 1900
[GENRE]      (%9) = Unknown
Padding Zeros        = 1
LogToScreen          = TRUE
LogToFile            = TRUE
DeleteWavFile        = FALSE
[LASTTRACK]          =
EXECUTE IF        = TRUE
NEW EXTENSION      = mp3
TEMPORAL FULL NAME = D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.mp3
TEMPORAL PATH ONLY = D:\ftp\music\general, rock\Tortoise
TEMPORAL NAME ONLY = 1tmp-!)!3
FINAL FULL NAME    = d:\ftp\_new\audio\music\Tortoise\mp3\Unknown Album\0. Unknown Title.mp3
FINAL PATH ONLY    = d:\ftp\_new\audio\music\Tortoise\mp3\Unknown Album
FINAL NAME ONLY    = 0. Unknown Title
EXECUTING: c:\program files\lame\lame.exe -V2 --vbr-new --ignore-tag-errors --ta "Tortoise" --tl "Unknown Album" --tt "Unknown Title" --tn "0" --ty "1900" --tg "Unknown" "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.wav" "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.mp3"
EXECUTION: SUCCESS
DIRECTORY "d:\ftp\_new\audio\music\Tortoise\mp3\Unknown Album" allready exists.
DELETING: d:\ftp\_new\audio\music\Tortoise\mp3\Unknown Album\0. Unknown Title.mp3 ... SUCCESS
RENAMING: D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.mp3 =] d:\ftp\_new\audio\music\Tortoise\mp3\Unknown Album\0. Unknown Title.mp3 ... SUCCESS
EXECUTE IF        = TRUE
TEMPORAL FULL NAME = D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.flac
FINAL FULL NAME    = d:\ftp\_new\audio\music\Tortoise\flac\Unknown Album\0. Unknown Title.flac
FINAL PATH ONLY    = d:\ftp\_new\audio\music\Tortoise\flac\Unknown Album
EXECUTING: c:\program files\FLAC\flac.exe -5 "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.wav" -o "D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.flac" -T artist="Tortoise" -T album="Unknown Album" -T title="Unknown Title" -T tracknumber="0" -T date="1900" -T genre="Unknown"
EXECUTION: SUCCESS
DIRECTORY "d:\ftp\_new\audio\music\Tortoise\flac\Unknown Album" allready exists.
DELETING: d:\ftp\_new\audio\music\Tortoise\flac\Unknown Album\0. Unknown Title.flac ... SUCCESS
RENAMING: D:\ftp\music\general, rock\Tortoise\1tmp-!)!3.flac =] d:\ftp\_new\audio\music\Tortoise\flac\Unknown Album\0. Unknown Title.flac ... SUCCESS
DeleteWaveFile is FALSE.
+++ DONE +++
NO errors ocurred.
MAREO 4 Released!
Reply #68
Nevermind. After I ran the EAC configuration wizard to reset my own modified settings and THEN pasted in the recommend mareo command line stuff it all worked fine! I guess I had something set in EAC previously that fouled it up.
MAREO 4 Released!
Reply #69
What settings do you have in EAC on the compression options, external compression tab ?
You should have "User external program for compression" checked
Parameter passing scheme = User Defined Encoder
Use file extension = .mp3
"Program..." = path to Mareo executable (I have E:\Program Files\Exact Audio Copy\mareo\mareo.exe)
Additional command line options: mareo.ini %s %d "%a" "%g" "%t" "%n" %y "%m"
"Add ID3 tag" should be unchecked.
MAREO 4 Released!
Reply #70
Thanks kwanbis!, works fine now.
Don't mean to nit pick but in the log where it says the file "allready" exists, should say "already" :-)
P.S. Did you know that mareo translates to "I am annoying" in both Google and Babelfish? Pretty funny
MAREO 4 Released!
Reply #71
good to hear
would fix it, thanks.
didn't knew  ... i know sometimes i'm
MAREO 4 Released!
Reply #72
I have 2 problems using mareo 4.04 und foobar 0.92.
1. problem:
- Mareo uses his installation directory as temp dir for the transcoded files
- Because of this i must use RENAME=TRUE for the first file type
- My foobar config looks like this:
Output filenames "single tracks": %artist%\%album%\%tracknumber%
Custom Encoder
Encoder: C:\Mareo\mareo.exe
Extension: mp3
Parameter: C:\Mareo\mareo_foobar.ini %s %d "%artist%" "%album%" "%title%" %tracknumber%" "%date%" "%genre%" %totaltracks%
- The process explorer shows the following parameters:
Path: C:\Mareo\mareo.exe
cmdline: "C:\Mareo\mareo.exe" C:\Mareo\mareo_foobar.ini "D:\mp3\Anne Clark\R.S.V.P\temp-077A7B3E0B0BE97C18FABCC38D0613AA.wav" "01.mp3" "Anne Clark" "R.S.V.P." "Up" 1" "1988" "Electronic" 14
current directory: D:\mp3\Anne Clark\R.S.V.P\
- The mareo log looks like this:
* Version 4.0.4 - Home Page at http://www.webearce.com.ar *
INIFILE       (%1) = C:\Mareo\mareo_foobar.ini
[SOURCE]      (%2) = D:\mp3\Anne Clark\R.S.V.P\temp-077A7B3E0B0BE97C18FABCC38D0613AA.wav
[DESTTMP]     (%3) = 01.mp3
[ARTIST]      (%4) = Anne Clark
[ALBUM]       (%5) = R.S.V.P.
[TITLE]       (%6) = Up
[TRACK]       (%7) = 1
[TRACKPADDED]      = 01
[YEAR]        (%8) = 1988
[GENRE]       (%9) = Electronic
[1]          (%10) = 14
Padding Zeros        = 2
LogToScreen          = FALSE
LogToFile            = TRUE
[LASTTRACK]          =
EXECUTE IF         = TRUE
NEW EXTENSION      = mp3
TEMPORAL FULL NAME = C:\Mareo\01.mp3
TEMPORAL PATH ONLY = C:\Mareo
TEMPORAL NAME ONLY = 01
FINAL FULL NAME    = d:\mp3\Anne Clark\R.S.V.P_\01.mp3
FINAL PATH ONLY    = d:\mp3\Anne Clark\R.S.V.P_
EXECUTING: c:\lame.exe --noreplaygain --nohist -m mono -q 2 --abr 64 --ta "Anne Clark" --tl "R.S.V.P." --tt "Up" --tn "1" --ty "1988" --tg "Electronic" --tc "EAC(0.95b4)LAME(3.96.1)abr 64 mono" "D:\mp3\Anne Clark\R.S.V.P\temp-077A7B3E0B0BE97C18FABCC38D0613AA.wav" "C:\Mareo\01.mp3"
EXECUTION: SUCCESS
DIRECTORY "d:\mp3\Anne Clark\R.S.V.P_" does NOT exists, creating ... SUCCESS
RENAMING: C:\Mareo\01.mp3 =] d:\mp3\Anne Clark\R.S.V.P_\01.mp3 ... SUCCESS
2. problem
- The mareo log shows also the second problem.
- Foobar creates the dir: d:\mp3\R.S.V.P
- Mareo creates the dir:  d:\mp3\R.S.V.P_
With foobar 0.8x mareo 2.2.0 uses the foobar destination dir as temp dir. I don't why this works different. I can test foobar 0.93b but the changelog shows nothing about directory handling etc...
MAREO 4 Released!
Reply #73
Hello again,
Is there a way in Mareo to configure it so that say '/' characters in the directory or file name can be replaced with a blank (or any other character of my choice) instead of the '_'?
The reason I ask is that typically I prefer to have any special characters replaced with blanks whereas Mareo prefers to put the '_' instead.
It's no big deal but I thought it could be a preference setting somewhere or maybe a new argument to the program something like
-r ":" " " -r "/" " "
or maybe
-r ":/?" " "
Thanks again for a great little program!
MAREO 4 Released!
Reply #74
i would take a look at both issues (fb2k, _) ASAP.
