Topic: Best AAC encoder (Read 55229 times) previous topic - next topic
Best AAC encoder
I'd go for Nero. 128 or 160, 192 kb/s/stereo is a waste of your harddisk space...
Best AAC encoder
iTunes won the AAC listening test @ 128kbps..
Best AAC encoder
yes but later versions of itunes had degraded audio quality.
Sven Bent - Denmark
Best AAC encoder
[a href="index.php?act=findpost&pid=247416"][{POST_SNAPBACK}][/a]
Only if you can listen above 16kHz.
Best AAC encoder
Hmm.. except the high frequency "issue" (which has been blown out of proportions on this board) the overall quality in QT 6.5.1 is better than the previous versions.
Best AAC encoder
[a href="index.php?act=findpost&pid=248490"][{POST_SNAPBACK}][/a]
Give me proof.
And I don't know what you understand by "out of proportions", but we have listening test results from board members showing that it indeed degraded quality. Where are your test results showing quality didn't degrade all that much?
Best AAC encoder
Does AAC have a LAME equivalent? Most people seem to use either itunes or Nero (from the sounds of things), but does anyone consider one to be "better" than the other?
If so, is there a specific verision that is preferred overall (e.g. LAME 3.90.3 rather than earlier or later variants)
<==== Hydrogen Audio Bomb
Best AAC encoder
[a href="index.php?act=findpost&pid=249421"][{POST_SNAPBACK}][/a]
No. Both iTunes and Nero offer high quality encoding, and neither seems to be obviously better than the other (quality-wise).
Best AAC encoder
What about FAAC? I've heard a bit about them and they seem to be mildly popular around the place.
I don't know too much about AAC, but I'm interested in ABXing it sometime, like OGG vs LAME vs AAC vs MPC :/
Best AAC encoder
[a href="http://www.hydrogenaudio.org/forums/index.php?showtopic=21904]Like this?[/url]
"Facts do not cease to exist just because they are ignored."
—Aldous Huxley
Best AAC encoder
Well I haven't seen that till now. Interesting. What's Vorbis aoTuV?
I found on rjamorim's site that FAAC doesn't score to well at all. In this test:
http://www.rjamorim.com/test/aac128v2/results.html
Its surprising how well iTunes did at 128kbps CBR, even beat Nero VBR which had an average of 140kbps
magic75 said: "Now that was a surprise... Lame as good as AAC??? Anyone expected that?"
Did he expect LAME to beat AAC? Or AAC to beat LAME?
BTW, what type of encoder does Winamp 5.05 use for AAC? It has two types: Raw and MP4 available. Have they ever been tested? I thought MP4 and AAC were the same, or is MP4 AAC an AAC encoded file in an MP4 container?
Bloody confusing lossy formats and technicalities, its enough to make me stick to .WAV's
Best AAC encoder
AAC to beat lame, for sure.
Remember AAC was developed to be the successor of MP3. So, you expect it to deliver better quality.
Also, the MPEG forum touts that AAC has 30% efficiency over MP3 - that is, it should sound the same at bitrates 30% smaller.
I think an explanation to what happened is that the Lame developers did a wonderful job taking the MP3 format to its limits. Lame is an excellent encoder and is already taking nearly the most of what the format can give. Most AAC encoders, on the other hand, are just past their infancy and have lots of room for improvements. It's also worth mentioning AAC is reportedly much harder to tweak than MP3.
[a href="index.php?act=findpost&pid=249853"][{POST_SNAPBACK}][/a]
"is MP4 AAC an AAC encoded file in an MP4 container" <- that's correct.
Winamp uses the Dolby encoder.
And no, I didn't test Winamp AAC. I kinda repent for it now, but this test's discussion became so catastrophic at one point, with people tampering polls, people getting into flame wars about what encoder to feature, and so on, that I decided it was enough and went with only the 5 encoders that were already chosen by then.
It wasn't my biggest mistake when conducing tests, though. Thankfully.
Regards;
Roberto.
Best AAC encoder
Vorbis aoTuV is essentially Ogg Vorbis 1.0.1 with special tunings done by Aoyumi.  Most of these tunings are now in Ogg Vorbis 1.1.
The AAC encoder in Winamp 5.05 seems to have problems with castanets.
http://www.hydrogenaudio.org/forums/index....showtopic=24285
I abxed it successful up to 224 kbps.
Best AAC encoder
[a href="index.php?act=findpost&pid=249856"][{POST_SNAPBACK}][/a]
Thanks for clearing that up. Any thing musical these days is very dependent on the situation. There's zillions of different encoders, decoders, transcoders, cd burners and software such as Nero that can all have an effect on apparent sound quality.
Not to mention the effect different sound cards, speakers or headphones can have
I was thinking about encoding all my songs into AAC (using Winamp), but that was before I came across EAC, LAME and FLAC (as well as a million other lossy and lossless formats).
What version of LAME was used in that test? I'm currently using LAME 3.90.3 (which supposedly has a lot of backing around the audio community as being the "best"). But I think I saw a test around here somewhere that suggested LAME 3.96.1 may be better
BTW, what is a container? I read a bit about it on the FLAC sites faq, but the concept still seems weird to me.
The current idea I have is that a container is just like a second format with added stuff that allows tags.
Is MP3 natively in a "container"??
What do you mean? Castanets as in the musical instruments?
Best AAC encoder
I'd say the time mp3 born is before the concept of a "container", so mp3 is just raw encoded stream with added feature such as id3tag.
Best AAC encoder
[a href="index.php?act=findpost&pid=250311"][{POST_SNAPBACK}][/a]
Yeah.  There are at least two killer samples that have castanets in it.  Winamp AAC had some problems encoding them transparently, even up to 224 kbps.
Best AAC encoder
3.96.1
3.96.1 wasn't as tested as 3.90.3. But I believe it's quality is probably on par with 3.90.3. I really don't believe quality degraded a lot, if it degraded. And it has the advantage of being much faster.
I use 3.96.1 for my MP3 encodings.
Best AAC encoder
QuickTime 6.5.2 and iTunes 4.7 were both released today with claimed quality improvements...
Best AAC encoder
[a href="index.php?act=findpost&pid=250321"][{POST_SNAPBACK}][/a]
Beliefs don´t count, you must provide proof that quality did not degraded a lot or a little.
(just kidding  )
Best AAC encoder
[a href="index.php?act=findpost&pid=250313"][{POST_SNAPBACK}][/a]
MPEG Layer 3 streams are most commonly contained in MPEG 1 containers.  However Mp3 can also be muxed into MPEG 2, MPEG 2.5, MPEG 4 or Matroska conatiners, perhaps there are some other which I missed.  Mp3 streams muxed into MPEG 2 or MPEG 2.5 containers usually still have the .mp3 extension.  AFAIK every type of multimedia file (maybe every file period) has to have some sort of container.
Best AAC encoder
There is no multimedia container wrapping MP3 streams. They can be considered RAW, since it's just the compressed information and frame headers, pretty much like ADIF AAC.
I don't consider frame headers a "container"
Also, if it was inside the MPEG "container", you would need an MPEG demultiplexer to playback MP3.
MPEG 1 and 2 don't have native containers. The video and audio streams are just multiplexed together, they are not wrapped inside something else.
MPEG 2.5 is just an extension to the MP3 standard for very low sampling frequencies. It doesn't make sense to speak about it as another MPEG multimedia portfolio.
Best AAC encoder
[a href="index.php?act=findpost&pid=259860"][{POST_SNAPBACK}][/a]
Are you sure about this ?
SebastianG
Best AAC encoder
SebastianG
[a href="index.php?act=findpost&pid=259871"][{POST_SNAPBACK}][/a]
That's what I have always seen in multiplexers. With several different ways to multiplex the streams: PS, TS, etc.
Best AAC encoder
[a href="index.php?act=findpost&pid=259874"][{POST_SNAPBACK}][/a]
I guess I did not understand what you mean by "native container". AFAIK the elementary streams are somehow packetized and then muxed on a packet basis.
SebastianG
