Topic: R128GAIN: An EBU R128 compliant loudness scanner (Read 402823 times) previous topic - next topic
Reply #425
Have you tried explicitely setting mode, reference level and gate?
No, just using the standard (R128-2011)
Jean
Reply #426
Hi folks.
Just a quick question.
I'm wondering how ISO 226:2003 compares to all the algorithms supplied by r128gain??
Has anybody experience with that one??
THX
SC
Reply #428
Many thanks for the hint.
You are welcome - thank you for your tremendeous work !
r128gain-1.0-alpha-6-3-win32-native performs perfectly.
Best regards
Jean
Reply #430
Thanks for the additon of the ATSC A/85 support and your continued work on this project.
Is there any difference between the following command line options ?
--a85               Run in ATSC A/85:2011 compliance mode.
--a85-2011          Run in ATSC A/85:2011 compliance mode.
Reply #431
Currently there isn't any difference. The idea is that in case the standard evolves "--a85" should always refer to the latest version.
Reply #432
Did you manage to have a look at the two issues (script/coredump)  I reported some posts back?
Reply #434
Thanks - I follow the logic
Reply #435
Hi.
--quiet
won't seem to work in latest alpha-6-3 cli-64.
Cheers
Reply #436
Hi there.
I'm preparing the big run now. On a couple of thousands songs I calculated more then 24 hours duration.
I tested the new Linux cli version ( as well as the old ones) on /tmp mounted into /dev/shm. And now on a HDD.
The HDD testrun is  >40% slower, than my /dev/shm (RAMDISK). And even the duration of  a conversion on ramdisk takes about 11s per track.
I'm wondering if r128gain uses a RAM buffer or if it stores the temporay files on disk.
If it buffers on HDD, things might get improved if I could select a "--temp=/tmp" option to use the RAMdisk as buffer.
What do you think?
Cheers
Reply #437
Okay I just ran into a crash on WinXP SP3...probably asking for it to some degree.
Firstly I removed from .\r128gain-tools\:
avcodec-54.dll
avdevice-54.dll
avfilter-3.dll
avformat-54.dll
avutil-51.dll
ffmpeg.exe
postproc-52.dll
swresample-0.dll
swscale-2.dll
I then set FFMpeg's path via the command line:
r128gain.exe --ffmpeg=..\FFMpeg\ ...(other commands)...
or
r128gain.exe --ffmpeg="W:\My Projects\Video Gain\BIN\FFMpeg\" ...(other commands)...
Both pathing methods resulted in a crash...now if I don't remove the above files...everything is fine...but given that since those files are present in a normal shared FFMpeg release...shouldn't that make the ones present in R128Gain redundant...and thus unnecessary?
However in ether case...required or not...R128Gain should catch the error and simply bitch...not blow up.
Another thing to note...when I went:
r128gain.exe --help > ReadMe.txt
I got a blank file...and not one that contained all the command line help information.
r128gain.exe --help
Does display everything correctly in the console...but I can't seem to pipe it to a text file.
Reply #438
Now I thought I read somewhere in the thread that R128Gain supported all formats that FFMpeg handles...It works fine with WAV & FLAC but when I try MP3 & AAC I get no love.
r128gain.exe --r128-2011 --true-peak --reference=-23 --in-place --tags=rg "C:\test\test.mp3"
Am I missing something?
Reply #439
You should update the FFmpeg DLLs from the sub-folder "r128gain-tools" with the corresponding from the latest Zeranoe build: http://ffmpeg.zeranoe.com/builds/win32/shared/.
Reply #440
or
I can't reproduce this one. Most likely you link to a binary incompatible FFmpeg. You should use the binaries from Zeranoe: http://ffmpeg.zeranoe.com/builds/win32/shared/
r128gain.exe --help
For whatever reason R128GAIN writes the help text to stderr and not to stdout. Please use
r128gain.exe --help 2> ReadMe.txt
Reply #441
Thanks for the quick reply.
I updated FFMpeg, both my independent install and the "r128gain-tools" which resulted in a working setup.
I was using a earlier build from zeranoe only a month or so old for my install.
So packaged R128Gain FFMpeg failed as noted prior...but once updated to the latest works fine.
However removing the files again as I noted in my prior post, and using --ffmpeg caused a crash yet again...so the --ffmpeg is mute since there is a dependency for having it in ".\r128gain-tools\".
Also --ffmpeg when using full path...if it has a trailing backslash it fails, but if it doesn't it works fine.
Works:
r128gain.exe --ffmpeg="W:\My Projects\Video Gain\BIN\FFMpeg" ...(other commands)..
Fails:
This issue isn't present when I performed relative pathing.
Works:
r128gain.exe --ffmpeg=..\FFMpeg ...(other commands)..
Thanks for all the help and effort on this project, it is appreciated.
Reply #442
Works:
Fails:
Works:
Many thanks for the detailed report. The error seems to be special to XP (we had already another one of this kind). Unfortunately I don't have access to XP during the next few days.
Reply #443
Hi.
Since I can not run the r128gain in script mode ( the bug still exists), I'd like to make another proposal for the cli version.
I used to check the files if rpg tags existed prior ro conversion. This way I avoid conversions where not needed.
That's very convenient if you scan your entire music directory all the time . Or if the conversion stops (forced stop) and restarts somewhere in the middle of the process.
Basically what's needed is an option that allows to skip conversion in case RPG tags exist.
I really hope that the script bug gets fixed sooner or later. Otherwise usage of r128gain is very limited in cli mode. Above I could have easily implemented by myself.
THX.
Reply #444
Hi there.
I just had one of those Murphy's Law experiences.
A huge batch conversion which was running for hours, just caused a core dump .
It was finished with the analysis of one CD at that point in time.
When starting to write the data to disc, r128gain dumped with:
"11000 Floating Point exception (core dumped)."
What a mess.
Now I do have to run the whole stuff all over again, since the problem mentioned in my last post,
won't let my continue where the program caused the core dump.
A  feature (option) that allows to skip  analyse files with already written rpg(EBU)-tags  would help a lot here.
Or even better - please try to fix my scripting issue. I can check it then by myself and run r128gain on a folder by folder basis.
THX
Reply #445
What a disaster.
I just figured that r128gain messed up some of my files in that last directory, where the coredump took place.
I've got some dead bodies called:
X92jzl.flac
kuzTIz.flac
LLQuv7.flac
One hint: It's been Hirez 24/88.2 data and 28 files in a single directory or so. Maybe there's resource issue. I do have 8GB RAM in my machine.
Reply #446
Two more things on the CLI.
1. File permissions gets changed to 600 and ownership gets also changed by r128gain
    It would be nice to protect file attributes or at least make sure that permissions are 666 after writing the new files.
2. While scanning the files a percentage counter runs. If you type "enter" that counter jumps randomly from one percentage to another ( far off) value.
    Not sure if that has any impact on the analysis.  It looks like problem on the first glance.
And one remark:
Just let me know if you're no longer interested in my feedback or the CLI version is put low on your priority list.
I noticed, that you obvisouly respond much quicker to other requests recently.
At least from my perspective - I'm encountering rather critical worst case issues - audio files are getting corrupted -  with this app and I'm willing to support.
At least a - "I'll look into it (next week/month/year)" or "I can't reproduce it" would be appreciated.
THX
Reply #447
I've uploaded a slightly enhanced version: http://sourceforge.net/projects/r128gain/files/r128gain/1.0/.
  • Now it should be possible to run the Linux/Linux64 CLI versions as a deamon.
  • Fails:
    I was not able to reproduce this. But anyway, the new version removes a trailing slash.
  • It would be nice to protect file attributes
    Now the Linux/Linux64 versions provide "--chown" and "--chmod" options for copying the respective attributes.
    Please note that overwriting the original files is not recommended. This is now emphasized by the help text.
Please note that FFmpeg's libavutil needs now to be version 52.
Reply #448
Info:
with Alpha-6-4 Linux-cli-64
--chown
--chmod
--progress=off
--quiet
don't work.
Reply #449
don't work.
What's the problem and how does it manifest? "Don't work" is a rather vague description
Stay sane, exile.
